    [SOFT] Arrm (Another Recalbox Roms Manager)
    Community projects
    another arrm manager recalbox roms
    35
    251
    193629
    • nexusone13
      nexusone13 @leowalk77 last edited by
      Hi @leowalk77 glad to read that you managed to get it work. I think you should change the bezels folder to something different that program files x86. It may cause error (access rights) if you check the overlay checkbox in image options tab.
      ARRM (Another Gamelist, Roms manager, and Scraper for Recalbox, Batocera, Retropie) : http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager
      Wiki ARRM: http://www.jujuvincebros.fr/wiki/arrm/
      Discord: https://discord.gg/p7QsBTS
      • nexusone13
        nexusone13 @leowalk77 last edited by nexusone13
        @leowalk77
        One more thing videomix only works with templates not using perspective generated images
        leowalk77 2 Replies Last reply Reply Quote 1
        • leowalk77
          leowalk77 @nexusone13 last edited by
          @nexusone13 said in [SOFT] Arrm (Another Recalbox Roms Manager):
          @leowalk77
          Good night!!! So that must be what was causing the problem, since I really only indicated the path to the ROMs folder, as I don't use Bezels, I left it aside, but I'll do as you indicated. ๐Ÿ˜ŽโœŒ
          Again, thank you very much for your attention. And about the Mix Videos I had noticed it!!! At first the program scared me because of the number of options it has, but with the help of a friend, I managed to learn the basics. The rest I'll see on your Youtube channel in addition to the Wiki page. ๐Ÿ˜‰
          • leowalk77
            @leowalk77
            Good Morning!!! Yes, I noticed this and whenever I go to create my scrapers I pay attention to these details. ๐Ÿ˜Ž
            Today I decided to do the ARRM test on my Notebook with Windows 11, which before was giving the same problem and I just indicated a new path for the Bezels folder that ARRM started to work perfectly. ๐Ÿฅณ
            Here is the directory tree I set up for the program:
            The only problem I had when running ARRM on my Samsung Flash F30 is that it doesn't adjust to the screen size of this notebook and because of that I didn't have access to some features that are at the bottom. ๐Ÿ˜ช
            The solution was to use the great feature of this new Windows that allows you to hide the taskbar. See below how the program looked after applying these changes:
            This is the total screen space of my notebook and as you can see even though I hide the taskbar some ARRM details are still missing, but the most important features for my use are accessible now. ๐Ÿ˜‰
            It would be good for you to come up with a way to make this program tuned for different types of screens to facilitate the final use. ๐Ÿ˜
            Thanks again so much for creating this amazing program for us end users. ๐Ÿ˜Ž
            RustyMG 1 Reply Last reply Reply Quote 1
            • RustyMG
              RustyMG @leowalk77 last edited by RustyMG
              @nexusone13 Hi all,
              Done a few new templates, and a few alternatives:
              Elektronika BK (better colour):
              Sufami addon:
              Videopac + / Videopac 7400:
              With the scraper, there is a problem with scraping EasyRPG games.
              It only allows a zip file, which is okay on a PC, however the Pi version of Easy RPG must have the folders unzipped, and in each folder, looks for the file "RPG_RT.ldb" to load the game.
              This file is the same for each game.
              I had to scrape as normal, unzip each game, then manually edit the xml file replacing the zip with "[game folder]/RPG_RT.ldb", but they all now work.
              Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
              nexusone13 1 Reply Last reply Reply Quote 1
              • nexusone13
                nexusone13 @RustyMG last edited by
                @rustymg said in [SOFT] Arrm (Another Recalbox Roms Manager):
                Hi @RustyMG
                Did you try this method ? :
                https://forum.recalbox.com/post/169526
                Just add .ini in the systemes_extensions.txt file
                RustyMG 1 Reply Last reply Reply Quote 0
                • RustyMG
                  RustyMG @nexusone13 last edited by
                  @nexusone13
                  Oops, forgot to include the alt Sega Saturn template.
                  Decided to make a nice one as Recalbox 7.3 will include the Sega Saturn.
                  CD case reduced in size and CD enlarged so they match better, and the grey console used to make it more visible.
                  • RustyMG
                    RustyMG @RustyMG last edited by
                    @nexusone13 Hi, was trying to resolve a VIC-20 problem and just noticed ARRM doesn't recognise .tap files, but, the VICE emulator can run them (go into Machine Settings -> Tape Port Devices and enable "Datasette Device".)
                    Can this suffix be added to the recognised file types so I can scrape these .tap games?
                    Many thanks ๐Ÿ‘
                    • RustyMG
                      @nexusone13 oops, and .d64 files too for the VIC-20?
                      Thanks !
                      • nexusone13
                        Hi @rustymg
                        You can add them by your own, follow the wiki :
                        http://jujuvincebros.fr/wiki/arrm/doku.php?id=add_extensions_en
                        I'll add them for the future release
                        • RustyMG
                          @nexusone13 Hi,
                          Yeah, I figured out how to add them and have done so, but thank you for adding to the next release ๐Ÿ‘
                          • cep
                            cep last edited by
                            necesito ayuda por favor estuve buscando informacion y todavia no encuentro la solucion, gracias
                            toniosj 1 Reply Last reply Reply Quote 0
                            • toniosj
                              toniosj Spanish moderator @cep last edited by
                              @cep ยฟQuรฉ problema tienes?
                              nexusone13 1 Reply Last reply Reply Quote 0
                              • nexusone13
                                nexusone13 @toniosj last edited by
                                Hi,
                                A new version of ARRM is available:
                                1.8.9.9 (09/12/2021)
                                • Addition of a scrape module on GOG: Recovery of media Logo, Fanart, Video, Screenshot (to choose from 4 available). Wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=scraper-gogdb-en (requested by Bob Morane on the ARRM Discord)
                                • Addition of a scrape module on Steam: Recovery of Boxart 2D media, Logo, Fanart, Video, Screenshot (to choose from 4 available). Wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=scraper-steamdb-en (requested by Bob Morane on the ARRM Discord)
                                • Addition of a scrape module on HFS-DB (db.hfsplay.fr) : Recovery of Boxart 2D / 3D media, Logo, Fanart, Video, Screenshot, Cartouche, Titleshot, Round Wheel. Wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=scraper-hfsdb-en (Requested by Bob Morane on Discord ARRM) (Thanks to hfsplay for API access)
                                • Changed the Scrape on TheGamesDB which now works as HFS-DB. WIKI : http://jujuvincebros.fr/wiki/arrm/doku.php?id=scraper-thegamesdb-en
                                • Gamelist creation is now faster for Windows / PS3 systems (requested by TVslan on Discord ARRM)
                                • In the 'Tools' tab, the 'Backup configuration files' button allows you to save the ARRM configuration files as well as the associated registry keys. Wiki http://jujuvincebros.fr/wiki/arrm/doku.php?id=save_restore_en
                                • In the 'Tools' tab, the 'Restore configuration files' button allows you to select and restore the ARRM configuration files as well as the associated registry keys
                                • When using the 'Rename with DAT' button, the 'temporary' tag is filled in with the DAT file in which the rom was found.
                                • when exporting to AttractMode format, the game description is saved in %romfile%.txt files in the Romlists save directory (the user must place them in the right place in his AttractMode configuration)
                                • Fixed the export option in CSV format no longer worked (thanks HadoKen)
                                • Fixed a bug which prevented to find the right platform (system) when your systems included capital letters in the files: systemes_screenscraper.txt, systemes_tgdb.txt, systemes_hfsdb.txt and systemes_gamesdatabase.txt (detected by Bob Morane on Discord ARRM)
                                • Fixed a bug where extensions were not taken into account when system names were not lowercase in systemes_extensions.txt (thanks Bob Morane)
                                • Fixed a bug that prevented saving image directory names in the folder tab (thank you [RGS] and Soaresden)
                                • Fixed bug on 'Delete media' button, boxbacks were not deleted
                                • Fixed a bug on loading the gamelist with the <folder> tag not containing the <image> tag or with the <image> tag empty
                                • Fixed a bug where 'PC / DOS as files' as well as 'systemes_as_folder.txt' were not taken into account.
                                • Fixed a bug when the 'system folder' only consisted of a drive name (E :, F: etcโ€ฆ) (thanks Knockthedoor)
                                • Fixed a bug that deleted '-extra1' images when using the 'Delete unused images and videos' button. They are no longer deleted for the moment. (thank you Nordicpower)
                                • Fixed various bugs
                                Download link for the full version via arrm_setup.exe (remember to uninstall the previous version): http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager
                                Download link for the full version without using arrm_setup.exe. (Allows you to install or update the application by copying files): http://jujuvincebros.fr/telechargements2/category/12-arrm-executable-only
                                Changelog : http://jujuvincebros.fr/wiki/arrm/doku.php?id=changelog-en
                                Beta versions page: http://jujuvincebros.fr/telechargements2/category/11-arrm-update-correctif
                                ARRM WIKI: http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=Start-en
                                Videos tutorial playlist: https://www.youtube.com/playlist?list=PLwA4JmSgv-PtLlzwPMOad5Ti96UfsbSzK
                                Discord ARRM: Discord: https://discord.gg/p7QsBTS
                                • nexusone13
                                  nexusone13 @nexusone13 last edited by
                                  Hi Everyone,
                                  1.9.0.0 (09/25/2021)
                                  • Addition of a scrape module on LaunchBox database : Recovery of Boxart 2D / 3D media, Logo, Fanart, Screenshot, Titleshot, BoxBack, Cartridge, Marquee. See Wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=scraper-launchbox-fr (requested by Bob Morane on the ARRM Discord)
                                  • Addition of systemes_launchbox.txt file for association between your systems and Launchbox systems. Consider adapting it to your system directory names.
                                  • Addition of the video preview on HFS-Db
                                  • Addition of regions in the HFS-DB module (request from Nordipower)
                                  • Addition of a 'Ignore platform on LaunchBox / TGDB / HFS' checkbox in the 'Recalbox / Batocera / Screenscraper' tab. Allows not to filter on the platform when searching for a game (Request from TVslan on Discord ARRM)
                                  • Addition of a button dedicated to exports without needing to create the gamelist (request from Banbs on ARRM discord)
                                  • Improved search on HFS-Db for games containing in their title ':'
                                  • In unit mode, on TGBD, LaunchBox, GOG, Steam, HFS-Db scrape engines, it is possible to modify the textual elements before validation and to choose the textual elements to recover
                                  • In 'Auto Validation' mode activated, it is now possible to ignore games when the search returns more than one game, via the 'Ignore when # games> 1' checkbox (in order to avoid manually validating each game)
                                  • Taking into account of the decimal separator used for the correct display of the rating (it is normally no longer necessary to modify the decimal separator in the windows control panel)
                                  • Removed empty lines in the description when saving the gamelist (request from Trinidad Sweet on Discord ARRM)
                                  • Fixed a bug: Videos and manuals were not fetched from HFS-Db
                                  • Fixed a bug: on HFS-Db some games were not displayed even though they were found
                                  • Fixed a bug / crash when 'Strict Search' was checked and the system was not present in systemes_screenscraper.txt (thanks Trinidad Sweet)
                                  • Fixed a bug on HFS / Steam / GOG / TheGamesDB module when auto-selecting when only one game is returned (images were not fetched)
                                  • Fixed a bug which replaced the name of the game with the name of the cleaned game (detected by Nordicpower)
                                  Discord ARRM: https://discord.gg/p7QsBTS
                                  • RustyMG
                                    Hi all
                                    Due to Recalbox 7.3 supporting some new systems, Ive created the templates so you can scrape their games in ARRM:
                                    Texas TI99/4a
                                    Tandy TRS80 color computer
                                    Dragon32
                                    BBC Model B
                                    LowresNX
                                    • nexusone13
                                      Hi @rustymg
                                      Thanks for your new templates.
                                      They are now in ARRM 1.9.0.1
                                      • nexusone13
                                        Hi everyone
                                        A new version of ARRM is available :
                                        ARRM 1.9.0.1 (10/09/2021)
                                        • Added the functionality of dragging and dropping images directly from websites on the Mix'Me module. Video : https://youtu.be/A6a2z0mgmkM
                                        • Possibility to filter the display of templates according to categories defined in the template XML. All XML has been updated. Video: https://youtu.be/wxIjZtWWblg
                                        • Updated configuration files for the next Recalbox 7.3
                                        • Addition of a "Media preview" checkbox (as well as a 'Media' button in the 'ROM Information' panel) allowing to have an overview of the existing media for the selected game.
                                          The checkbox automatically activates this preview which will also be visible in the Steam / Gog / HFS-DB / LaunchBox scrape modules. Video: https://youtu.be/wTk6ttmW2lc
                                        • Addition of clickable Wikipedia and Youtube links on the LaunchBox module
                                        • Addition of 8 templates by RustyMG (BBC Model B, Dragon 32, LowRes-NX, Saturn, PC88, PC98, TRS-80 Color Computer, TI-99 / 4A)
                                        • Bug fix: The 'Game name' checkbox is taken into account
                                        • Bug Fix: Now, when the database is empty, the 'Information Rom' Panel is emptied and inactive
                                        • Bug fix: crash related to filters in search / replace modules
                                        Donwload links:
                                        Full version via arrm_setup.exe (remember to uninstall the previous version): http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager
                                        Full version without using arrm_setup.exe. (Allows you to install or update the application by copying files): http://jujuvincebros.fr/telechargements2/category/12-arrm-executable-only
                                        Keep in touch : http://jujuvincebros.fr/wiki/arrm/doku.php?id=contact-en
                                        • nexusone13
                                          Hi everyone,
                                          1.9.0.2 (11/20/2021)
                                          • Addition of a button to access the 'Launchbox media assignment' screen which allows you to assign the various Launchbox media to the TAGs available in ARRM. (To do before a scrape.) See: http://urlr.me/4MHJ5
                                          • Addition of an 'Edit Arcade Systems list' button in the 'Tools' tab which allows you to edit the list of systems to be considered as Arcade
                                          • Addition of a button to update the search database by Datfiles. See wiki for the operating mode: http://urlr.me/6vxQX
                                          • Update of the database for the search of names via Datfile: on arcade roms, there were many inconsistencies. (bug report by ZenGeek on Discord ARRM)
                                          • When loading a gamelist containing tags unknown to ARRM (cheevosHash, cheevosId ...), ARRM keeps them in a database (extra_tags), and rewrites them when creating the gamelist.xml and gamelist_ARRM. xml.
                                          • Addition of a 'Gamelist TAGs' tab which allows you to select the media TAGs that you want to appear in Gamelist.xml. If the associated media exists the TAG will be written. When creating gamelist.xml, a gamelist_ARRM.xml file containing all available tags is also created. If you want to use the 'Recompose image' function, it is important to check the 'Use Gamelist_ARRM.xml' checkbox when you load a system in order to have all the media available.
                                          • Addition of the checkbox 'Activation of 4 images mode' in the 'Image options' tab (request from Pajarorojo on ARRM discord)
                                          • When the '4 images mode' is not checked, it is possible to request the download of: screenshot, boxart, marquee, cartridge. (4 images mode automatically downloads them) (request from Pajarorojo on ARRM discord)
                                          • On a blank ARRM configuration, the media associated with WHEEL is assigned to the MARQUEE tag (request from Pajarorojo on ARRM discord)
                                          • Addition of an 'Add language' Checkbox in 'Scrape Options' tab: Finds languages ??in the file name when loading the gamelist and assigns it to the language field if it is empty. Also works with the 'Check Roms' button
                                          • Added the search for music on GamesDB when scraping on HFS-Db / Launchbox / TheGamesDB (if GamesDB music is checked in the Scrape Options tab)
                                          • Added titlescreen and favorite metadata in Pegasus exports (macche request on Discord ARRM)
                                          • Addition of a 'ScummVM folders' checkbox in the 'Gamelist Options' tab: allows, if Batocera is selected, to create <folder> tags with game information (enabled by default)
                                          • Correction: on HFS-Db sometimes screenshots present on HFS-Db were not found.
                                          • Correction: on HFS-Db sometimes the platforms were not mentioned in the search result.
                                          • Correction: When the 'Activation of 4 images mode' is not checked, some image media were not saved via the new scrape modules.
                                          • Correction: The existing folder tags are retrieved and rewritten when saving the gamelist.xml
                                          • Correction: Moved the 'Default image + video' button in the 'Images options' tab
                                          • Updated configuration files to support the following systems: Adventure Vision (advision), CD-i (cdi), CreatiVision (crvision), PV-1000 (pv1000), Game.com (gamecom), Gamate (gamate), TV Games (tvgames), Fujitsu FM-7 (fm7), Game Pocket Computer (gamepock), APF M-1000 (apfm1000), BBC Micro (bbc), Coleco ADAM (adam), Arcadia 2001 (arcadia ), Game Master (gmaster), Bally Astrocade (astrocade |), TI-99 (ti99), Tomy Tutor (tutor), Tandy Color Computer (coco), & Mega Duck (megaduck)
                                          • Addition of templates for these new systems. See: http://urlr.me/XqyHZ
                                          • Addition of a template: mix_neogeo_zengeek
                                          • Addition of teknoparrot in the configuration files (remember to check 'Ignore the platform on Lanchbox / TGDB / HFS' in the 'Batocera / Recalbox / Screenscraper' tab for better results on teknoparrot)
                                          Donwload links:
                                          • nexusone13
                                            Hi everyone,
                                            1.9.1.0 (01/17/2022)
                                            • Addition of a 'Without Artwork only' checkbox in the 'Scrape Options' tab which only processes ROMs for which the visual media (checked in the 'Images Options' tab) are missing. Only missing media will be recovered. Scrape modules other than Screenscraper will only show you the missing media. Ideal to complete your collections. See WIKI : http://jujuvincebros.fr/wiki/arrm/doku.php?id=scrape_missing_artwork_only_en
                                            • Added some selectable fields in the replacement module
                                            • Addition of a 'Delete Artwork(s)' button which allows, for the selected game, to delete the desired artwork(s).
                                            • Addition of xbox360 template
                                            • Addition of an 'ARRM folders' checkbox in the 'Gamelist Options' tab: When saving the gamelist.xml, allows ARRM to automatically create <folder> tags if it finds the following files in the directories current system: 'folder-name of the folder.png' and 'folder-name of the folder.txt'. Uncheck if you use your own <folder> tags "
                                            • Addition of a 'ScummVM folders' checkbox in the 'Gamelist Options' tab: For Batocera, when creating the gamelists for the ScummVM and ResidualVM systems, automatically created the <folder> tags for the games.
                                            • Addition of configuration files for the xbox360 system added in Batocera by Foclabroc
                                            • Added a 'Create empty Rom file when no exists (Dev)' checkbox in the 'Tools' tab: When loading a gamelist.xml, if the ROM file does not exist, ARRM will create an empty ROM file . This feature is used by the developer to test user gamelists and detect anomalies. This option is not stored.
                                            • Bug correction: during a scrape on Launchbox, the previously scraped video file was deleted. (detected by Nordicpower)
                                            • When changing the template, the template thumbnail is updated
                                            • For HFSDb you can activate the 'Exact search' checkbox when the game title contains :
                                            • Fixed a bug which sometimes prevented the copying of <folder> tags when creating the gamelist.xml
                                            • Update of the Steamdb and LaunchBox database
                                            Donwload links:
                                            Donations : http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=donations-en
                                            101.0k
                                            Copyright ยฉ 2021 recalbox.com
