    Recalbox not allowing browsing over the network
    recalbox allowing browsing network
    3672
    • astlaurent
      astlaurent last edited by
      Hi
      I am loving 4.1 so far. The only problem i have found is it is not allowing me to browse to the recalbox to load roms for example \recalbox in windows does not open the share. I also tried \IP as well.
      Substring m0nkey 2 Replies Last reply Reply Quote 0
        Substring @astlaurent last edited by
        @astlaurent hi
        This is a windows configuration problem. It works fine for everyone
        • astlaurent
          I will look around but it did work when I was in 4.0
          What could cause such a problem. I can http and ssh to the pi so I know network wise it is fine
            OyyoDams Staff @astlaurent last edited by
            @astlaurent take a look at Windows network parameters, it might be configured as "public" network and not "private" network.
            astlaurent 1 Reply Last reply Reply Quote 0
            • astlaurent
              astlaurent @OyyoDams last edited by
              @oyyodams said in Recalbox not allowing browsing over the network:
              It works from another computer so it must be something with my windows install. Sorry not a recalbox problem
              • m0nkey
                m0nkey @astlaurent last edited by
                @astlaurent This problem occurs because Windows (I assume you use Windows 10) uses the actual windows account to login into SMB-Shares. Normally you should then be remapped to a an guest account (because recalbox does not know you windows user), but Windows seems not to accept it and denies the access to the network share or the remapping from samba does not work correctly. I did not investigate further. Anyway, if you remove the "map to guest=bad user" property from smb.cfg at the recalbox, Windows will ask you for login information.
                101.4k
