    Solved SCUMMVM structure
    Emulator Arcade/PC/Console
    scummvm structure
    7755
    • pmroyo
      pmroyo last edited by
      Hi all
      I wanted to reply to the following post but as is an old one, maybe is a better idea to open a new one. I have been reading several posts in english, french and spanish but I am not sure about the best files structure for this emulator. Currently I have 2 games. For both games I have the empty file as shortname.scummvm:
      Once I have executed the universal scrapper, this is the result:
      Game 1, folder named without .summvm: it appears as a subfolder in the emulation station without screenshot or data and once I click on it, the game appears with data and screenshot.
      Game 2, folder named with scummvm: I have no data or screenshot in the list but once I click on it, I access directly to the game.
      Which is the best option? I was trying to follow this wiki but people in the forum say different things
      Thanks in advance
      • abunille
        abunille @pmroyo last edited by
        @pmroyo
        Hi,
        my best option is how described in the blog:
        https://www.recalbox.com/blog/en/post/blog-2017-11-10-recalbox-17.11.10/
        roms/scummvm/tentacle.scummvm (folder)
        Inside the tentacle.scummvm folder a file called tentacle.scummvm
        Then Scrape with internal scraper.
        • pmroyo
          @abunille So, universal XML scrapper won´t work by this way? only the internal scrapper?
          • abunille
            abunille @pmroyo last edited by abunille
            @pmroyo
            Yes, how I know UXS not work with folder at the moment.
            With the internal scraper you also can scrape via ScreenScraper 😉
            pmroyo 1 Reply Last reply Reply Quote 0
            • pmroyo
              pmroyo @abunille last edited by
              @abunille I am trying to scrape the games with the internal tool but is not working, it shows the following message:
              I have tried scraping the scummvm and with every single game, but the result is the same. Do you know what I am doing wrong?
              • abunille
                @pmroyo
                Have you tried with shortname? (monkey.scummvm)
                On your screenshot you don't use it.
                pmroyo 1 Reply Last reply Reply Quote 1
                • lmerckx
                  lmerckx last edited by lmerckx
                  If you use Screenscrapper as scrapper (even internal), you have to know that very few ScummVM and Dosbox games are known.
                  Check here: https://www.screenscraper.fr/gamesinfos.php?plateforme=123&alpha=0&numpage=0
                  (only 2 games)
                  Prefer GamesDB for these two systems.
                  For me, it works !
                  Recalbox 9.1 on RPI 4, SSD 250Gb, 2 Logitech F710, Nespi4case
                  Contributions for DosBox, ScummVM, ResidualVM, Daphne (Hypseus)
                  • abunille
                    abunille @lmerckx last edited by
                    @lmerckx
                    Thats not right.
                    Your link goes to alphabet #
                    For Monkey Island as example check here 😉
                    https://www.screenscraper.fr/gameinfos.php?plateforme=123&gameid=99855
                    • pmroyo
                      @abunille Done. My mistake was use the long name in the folder and the short name in the file, instead of using short name in both.
                      Thank you very much
                      • abunille
                        @pmroyo
                        You are welcome 🙂
                        • lmerckx
                          Oups ... sorry for my mistake.
                          • lmerckx
                            Stupid question : should'nt we add long names as ROM too ?
                            It will allow to recognize directories with complete game name too ...
                            • abunille
                              abunille @lmerckx last edited by abunille
                              @lmerckx said in SCUMMVM structure:
                              No problem dude, all good 🙂
                              The Question with long name is not stupid. I think it can be a good idea.
                              But I don't know if it works.
                              I will check that.
                                Substring @lmerckx last edited by
                                @lmerckx This might as well be a problem on the ScreenScraper API, not just how games are referenced.
