    Solved Scummvm stopped working 4.1
    Emulator Arcade/PC/Console
    scummvm stopped 4.1
    4706
    • Styrkjar
      Styrkjar last edited by
      Hi there
      Scummvm seemed to stop working since the update to 4.1
      It worked fine before, so the *.scummvm files are in the right location.
      After the update the games are still there but won´t start. (Screen turns black and returns to recalbox after a few seconds)
      • lmerckx
        lmerckx last edited by
        Can you check in logs directory ?
        Is there some information on stdout / stderr files ?
        Recalbox 9.1 on RPI 4, SSD 250Gb, 2 Logitech F710, Nespi4case
        Contributions for DosBox, ScummVM, ResidualVM, Daphne (Hypseus)
          Substring @Styrkjar last edited by
          @styrkjar Regression has been tested, it was still working as expected. Can you make a support archive ?
          Styrkjar 1 Reply Last reply Reply Quote 0
          • Styrkjar
            Styrkjar @Substring last edited by
            @substring
            I´m not a native englishspeaker, so I´m apologizing in advance for some possible misunderstandings.
            I don´t know how to make a support archive. To be honest I also don´t know what´s a support archive in the first place.
            I do know, where the logs directory is located. Should I post the text in the *.stdout and *.stderr files?
            • Styrkjar
              Styrkjar @Styrkjar last edited by
              stdout.log is empty
              stderr.log contains:
              Traceback (most recent call last):
              File "/work/output/target/usr/lib/python2.7/site-packages/configgen/emulatorlauncher.py", line 210, in <module>
              exitcode = main(args)
              File "/work/output/target/usr/lib/python2.7/site-packages/configgen/emulatorlauncher.py", line 139, in main
              command = generators[system.config['emulator']].generate(system, args.rom, playersControllers)
              File "/usr/lib/python2.7/site-packages/configgen/generators/scummvm/scummvmGenerator.py", line 23, in generate
              romFile = glob.glob(romPath + "/*.scummvm")[0]
              IndexError: list index out of range
              • Styrkjar
                And here´s an image of the files.
                abunille Substring 2 Replies Last reply Reply Quote 0
                • abunille
                  abunille @Styrkjar last edited by abunille
                  @styrkjar
                  Enter Webmanager with http://recalbox/
                  Press on the left side Support or Hilfe
                  Then you press the button to create an support archive and post the link to the file here.
                  btw:
                  you have no scummvm "file".
                  Your Structure must be for example:
                  ....roms/scummvm/monkey2.scummvm (monkey2.scummvm is a folder)
                  Inside the monkey2.scummvm "folder" you must place your game files and a "file" called monkey2.scummvm
                    @styrkjar you got it wrong. Olease read again the blog post as monkey island 2 was my example
                    • Styrkjar
                      Okay I just tried the way @abunille promoted and it worked perfectly.
                      Case solved, thanks a lot.
                      But the Way my files were organised did work with version 4.0.1, but I don´t have any idea why...
                      • abunille
                        @styrkjar
                        When all is good now, you can mark this Thread as solved.
                        Look at my signature, you understand this language 😉
                        • Styrkjar
                          already did that. Thanks for the help. 😉
                          • abunille
                            @styrkjar
                            Gerne
                            You are Welcome
                              @styrkjar because we don't search in sub-folders, @lmerckx will confirm.
                              • lmerckx
                                To be honest, I haven't tested this kind of structure.
                                The recommended ones are :
                                1)
                                scummvm/NAME OF THE GAME
                                with shortname.scummvm inside game directory
                                scummvm/NAME OF THE GAME.scummvm
