    Solved Aspect Ratio Problem with PSX (Retroarch) on RPI3 Recalbox 01.12.17
    Emulator Arcade/PC/Console
    aspect ratio retroarch rpi3 recalbox
    • Backpaddle
      Backpaddle last edited by
      Since the first day, i have the problem that the screen aspect ratio is fixed at 4/3, with Magic Key + X i can get in the Retroarchmenu and choose 16/9 for my TV.
      But when i close the game and restart it, i got 4/3 instead of the 16/9. I try to manual change it via a .cfg in the recalbox.cfg or the pcsx-rearmed.cfg (didnt find the retroarch config itself).
      Dont know what i can do more, it is a little problem but it make me sick.
      btw. i use the sd card + usb stick solution.
      • Xanarkan
        Xanarkan last edited by
        Normally you can choose directly from EmulationStation -> start -> game settings -> games aspect ratio.
        Raspberry Pi 3b @1.3 GHz | Xbox 360 Controllers | Recalbox 4.1
        HTPC: Intel Core i5 4570S @2.9 GHz | Intel HD Graphic 4600 | Kingston KHX1600C9D3 4 Go DDR3 | Asus H81M-PLUS | Asus Xonar DX
        Backpaddle 1 Reply Last reply Reply Quote 0
        • Backpaddle
          Backpaddle @Xanarkan last edited by
          @xanarkan yes, but it didn´t save this, i must do this everytime i start a game.
          But i found a fix by myself. I fix the resolution and aspect ratio in the configs and edit that the ratio is not given from the core.
