    hifi DAC config /etc/asound.conf get problem,need help
    GamePad/GPIO/USB encoder
    hifi dac config etcasound.conf problem,need
    • sanjiuwan
      sanjiuwan last edited by
      I got a hifi DAC,it work perfectly at osmc.but when I try recalbox following this "create the file /etc/asound.conf",it can't work,it say read-system file,but I used the root to login from putty.pls help me,thanks a lot.
      I follow this link
      https://github.com/recalbox/recalbox-os/wiki/Audio-HiFiBerry-(EN)
      • Dragu
        Dragu Banned last edited by
        @sanjiuwan
        You must first get the right to write on the disk,
        /etc
        --->  mount -o remount, rw /
        Some interesting reading for you
        https://forum.recalbox.com/topic/9368/no-more-sound-after-installing-v-4-1-in-recalbox/201
          Substring @sanjiuwan last edited by
          @sanjiuwan You don't need at all to create that file to be honnest. Just editing the config.txt is enough.
          • lackyluuk
            @Substring I should mark it as optional in the wiki. According to Hifiberry it's only to configure alsa.
              Substring @lackyluuk last edited by
              @lackyluuk Recalbox does it itself since 4.1 when selecting a sound device in ES
              100.9k
