    Solved Dreamcast - MMU not supported --> can't run some games?
    Emulator Arcade/PC/Console
    dreamcast mmu supported cant run
    5587
    • unik314r
      unik314r last edited by
      Hi,
      I can run a lots of DC games (Crazy Taxi, Marvel vs Capcom 2, Resident Evil Code Veronica etc etc...) but I can't run TOMB RAIDER CHRONICLES.
      I tried 2 different CDIs, same issue: BIOS boots, but game won't load --> I come back directly to ES.
      Here are some logs:
      • @@ ngen_Res==============================================
        etBlocks()
        Freeing fpcb
        recSh4:Dynarec Cache clear atPowering on HDMI with preferred settings
        AC09EC6E
        Sh4: i-cache invalidation AC00043A
        @@ ngen_ResetBlocks()
        Freeing fpcb
        recSh4:Dynarec Cache clear at AC00043A
        bm_GetBlock(001D2ED4) failed ..
        Stale block ..bm_GetBlock(001D2ED4) failed ..
        .. null RBI: AC000452 -- unlinked stale block
        Freeing fpcb
        recSh4:Dynarec Cache clear at AC0082FE
        Sh4: i-cache invalidation AC0082FE
        Freeing fpcb
        VREG = 03 ARMRST 00
        DIV32S matched 1% @ 0x8C0098D8
        DIV32S matched 100% @ 0x8C0098DE
        div32s 1/0/3
        DIV32S matched 1% @ 0x8C009A36
        DIV32S matched 100% @ 0x8C009A3E
        div32s 1/0/3
        DIV32S matched 1% @ 0x8C009AC0
        DIV32S matched 1% @ 0x8C009ACA
        reicast git/n - 10.28 (0.00) - 97.20 - V: 48.60 (49.49, PAL480i50.00) R: 0.98+0.00 VTX: 0.00 , MIPS: 0.00
        Sh4: i-cache invalidation AC00E0DA
        Freeing fpcb
        recSh4:Dynarec Cache clear at AC00E0DA
        bm_GetBlock(001D2B08) failed ..
        Stale block ..bm_GetBlock(001D2B08) failed ..
        .. null RBI: AC00E0FC -- unlinked stale block
        SPI : unknown ? [0x70]
        SPI : unknown ? [0x71]
        Freeing fpcb
        recSh4:Dynarec Cache clear at AC00FFFE
        Sh4: i-cache invalidation AC013402
        Freeing fpcb
        recSh4:Dynarec Cache clear at AC013402
        <* * * * * * >MMU Enabled , ONLY SQ remaps work< * * * * * *>
        MEM remap 0 : 0x5800 to 0xC129800
        Get MemPtr unsupported area : addr=0x5B90
        Error in ../../core/hw/holly/sb_mem.cpp:WriteBios:69 -> Write to [Boot ROM] is not possible, addr=c,data=8c026390,size=2
        Verify Failed : !(state.cpu.is_delayslot && OpDesc[op]->SetPC())
        in dec_DecodeBlock -> ../../core/hw/sh4/dyna/decoder.cpp : 1101
      --> I can see <>MMU Enabled , ONLY SQ remaps work<>
      I could read on the net that it may be the reason why: do you agree?
      Is there any solution to run Tomb Raider Chronicles?
      Thanks a lot!
      • lackyluuk
        @unik314r I will test the game later this evening. Can give you some feedback then if it works for me.
        • abunille
          abunille @unik314r last edited by abunille
          @unik314r
          Hi,
          it doesnt work.
          I tried the german one (gdi) and also no success.
          In compatibility list it is also marked as "not working":
          https://docs.google.com/spreadsheets/d/1Ep2Lm_nhpXtLp-iZibFXiCZUB7csqWXFzqj8IvvGOJk/edit#gid=1806295408
          Yep, the problem seems to be MMU:
          https://github.com/reicast/reicast-emulator/issues/53
          • unik314r
            @abunille said in Dreamcast - MMU not supported --> can't run some games?:
            ... Forgot to check this list...
            Well, I guess I'll have to play TR Chronicles on PSX 😉
            Ok thanks a lot 🙂
            • abunille
              @unik314r
              No problem 😉
              I hope it works on psx.
              You can then edit the compatibility list psx. thank you for your help 😉
              https://docs.google.com/spreadsheets/d/1-gxB5A2aRvFVJWcyaPs-f7uYLeQb8aHMDavcDxAMncM/edit#gid=883336612
              Much success 🙂
              • unik314r
                @abunille Yes it does 🙂
                I've also updated some status for some other games (I'll try to do it as often as possible 🙂 )
                See you!
                abunille 1 Reply Last reply Reply Quote 1
                • abunille
                  @unik314r
                  Thank you
                  Have fun with playing 😉
                  And dont forget to mark this topic as "solved" .
                  see my signature laugh
                  unik314r 1 Reply Last reply Reply Quote 0
                  • unik314r
                    unik314r @abunille last edited by
                    @abunille Can you tell me how I can set this topic as solved please?
                    • abunille
                      @unik314r
                      Good morning,
                      Topic Tools -> Ask a question + Topic Tools -> Mark as Solved
