    PSX memory card format is the same for bin/cue and pbp files?
    Emulator Arcade/PC/Console
    memory card format same bincue
    • nwildner
      nwildner last edited by
      Hi folks 🙂
      I'm doing some research on PBP files, and since they use less disk space i'm migrating to use them.
      My memory card files at \\recalbox\saves\psx will be recognized by the emulatior without any kind of conversion if i use same basename of the file with .srm extension ?
      PT_BR Retrogaming on Telegram
        paradadf Staff @nwildner last edited by
        @nwildner I’m not sure but they are definitely compatible! In the qorst case, you can just rename it properly.
        nwildner 1 Reply Last reply Reply Quote 0
        • nwildner
          nwildner @paradadf last edited by
          @paradadf I'll try with Diablo from PS1 as soon as i get home, and post my findings here...
