    Cannot enter Configuration Menu with both controller and keyboard
    cannot enter both keyboard
    2794
    • antpicc
      antpicc last edited by
      Hi! I'm having problems with both my Xbox controller and my keyboard. I don't manage to enter the Configuration Menu, even by pressing START, or keeping it pressed for a while. I read on the wiki this is what one is supposed to do...but nothing happens to me...any idea?
        Substring @antpicc last edited by
        @antpicc Hi,
        what recalbox version ? how did you format your SD ? where does your Recalbox img/archive come from ?
        • antpicc
          antpicc last edited by antpicc
          @Substring I'm afraid I'm not provided with any of this information, apart from the RecalBox version. I was given the Rapsberry Pi as a gift, and RecalBox was already there.
          antpicc 1 Reply Last reply Reply Quote 0
          • antpicc
            antpicc @antpicc last edited by
            @Substring the first screen tells me kind of version 4.0...
            • Jonas Lauber
              Jonas Lauber last edited by
              Same problem hier... Just downloaded and installed it on a brand new SD... Cannot select anything on the menu with the keyboard...
              Jonas Lauber 1 Reply Last reply Reply Quote 0
              • Jonas Lauber
                Jonas Lauber @Jonas Lauber last edited by
                My bad... The config of my keyboard had just nothing to do with everything I could find on the web... It actually works.
                101.4k
