    4.1 Update doesn't work
    4.1 update doesnt
    3754
    • lordizak
      lordizak last edited by
      Hello everyone!
      When I try to update my recalbox from 4.0.2 to 4.1 it shows the "work" button for a very long time and then the system tells me that the update wasn't succesful and that the system will reboot. What should I do!? I really don't want to copy all my games two and external device - I think I would lose all my scraper works and a lot of time.
      Thank you!
        OyyoDams Staff @lordizak last edited by
        @lordizak Hi,
        You should always make a backup before upgrading. Sometime things go wrong. That's a good advice for everyting with computers, and that applies to Recalbox!
        Besides, if the automatic update system doesn't work, you'll have to install 4.1 from scratch. The good point is you'll have a fresh system.
        Good luck 🙂
          Hello,
          can you try by ssh this command. If there is errors, copy/paste them.
          bash -x /recalbox/scripts/recalbox-upgrade.sh
          lordizak 1 Reply Last reply Reply Quote 0
          • lordizak
            lordizak @rockaddicted last edited by
            @rockaddicted
            I am a real noob - can u explain it for me
            like for a 10 year old boy?
              rockaddicted @lordizak last edited by rockaddicted
              @lordizak https://github.com/recalbox/recalbox-os/wiki/accès-root-sur-Terminal--(FR)
              si tu es sous windows, télécharge et install putty.
              Tu devra saisir l'adresse ip de ta recalbox, et te logger avec les identifiants ID root et PASS recalboxroot.
              une fois loggé tu arrives sur une page noire avec un # en début de ligne. C'est là que tu copie/colle la commande donnée précédemment (sous putty, pour coller du texte, fait maj+inser depuis ton clavier).
              • lordizak
                @rockaddicted
                Thank you! Problem solved
