    rewind buffer doesn't flush correctly - aladdin snes
    Emulator Arcade/PC/Console
    rewind buffer doesnt flush correctly
    4004
    • Mathieu Shamok Poirier
      Mathieu Shamok Poirier last edited by
      Hi,
      i was playing aladdin on snes and use rewind function.
      sometime (not every time) the rewind buffer is already full or rewind for half a second ... while i was not using it !
      now, I can't trust the rewind function
      For Information: I never had this issue on 4.0
      • ramaduc
        ramaduc last edited by
        Hello,
        I have the exact same problem. Is there a way to fix that by increasing the memory buffer size ?
        Never occured on 4.0.2
        Thanks.
        • Dragu
          Dragu Banned last edited by
          @ramaduc
          Exactely, if you increase the rewind time, the problem resolve. I put
          rewind_buffer_size=50 Never a problem again.
            thanks , i'm gona try that.
            but still that's wired .. most of the time the buffer is working perfecly with "normal size".
              @dragu
              where did you add rewind_buffer_size=50 ?
              I tried in recalbox.conf
              global.rewind=1
              global.rewind_buffer_size=50
              => work for a while then bug
              global.rewind=0
              snes.rewind=1
              snew.rewind_buffer_size=50
              => same bug
              • Dragu
                @Mathieu-Shamok-Poirier
                the variable name is exactly what I told rewind_buffer_size=50, so better stay the other untouched.
                And it is in the retroarch menu that you can call in every snes game by Hotkey+B.
                But you can also change directly in retroarch.cfg or retroarchcustom.cfg, depending what you use.
                  @Dragu
                  thank for the details ... i'm gonna check that
