    Save/Load and Rewind feature on Dreamcast emulator (4.1.0)
    Emulator Arcade/PC/Console
    saveload rewind feature dreamcast 4.1.0
    4378
    • Aleksey  Yashcher
      Aleksey Yashcher last edited by
      Just one question — it's works or doesn't? I play on microsoft xbox 360 wired controller and special button which should do all these feature like save, load, rewind, etc. — just close emulator and exit to dashboard.
        HELLO @Aleksey-Yashcher
        reicast is not a core libretro in retroarch.
        you need to search : vmu options may be
        https://forum.recalbox.com/search?term=VMU&in=titlesposts&sortBy=relevance&sortDirection=desc&showAs=posts
        Aleksey  Yashcher 1 Reply Last reply Reply Quote 0
        • Aleksey  Yashcher
          Aleksey Yashcher @acris last edited by
          @acris said in Save/Load and Rewind feature on Dreamcast emulator (4.1.0):
          @acris tnx, maybe i'm incorrectly said, but ingame dreamcast save feature works fine, it's saving on vmu and loading too.
          I'm saying about «quicksave» feature, like it's on playstation and other liberto core emulators, does reicast hav these feature?
            @Aleksey-Yashcher
            i dont know, you need to reicast team to ask feature.
            ->https://github.com/reicast/reicast-emulator
            • lhari84
              lhari84 last edited by
              I'm also wondering if there is a possibility to do a "save state" like with the libretro-based emulators in Recalbox (using Hotkey + ⬜ or Hotkey + Y (depending on used gamepad)).
              Unfortunately I have not found anything yet, if Reicast is able to do it and if, how to activate in Recalbox...
              Would be also interresting for the N64 emulator, which isn't based on libretro too...
              Pi 4:
              Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
              Pi Zero 2W:
              GPi Case 2W, Recalbox 9.0
                Reicast is a stand alone emulator and doesn't support such functions. Otherwise I would have added key combos
