    Hide Build string on various splash screens
    Themes & Interface
    hide build string various splash
    4312
    • Aaron Stevenson
      Aaron Stevenson last edited by
      Hello!
      Is there a way to prevent the build string (recalbox version #) from displaying on boot or while launching a game? I don't mind the recalbox logo showing, but the extremely long build string at the bottom looks tacky.
      • idarius
        idarius last edited by idarius
        Hi,
        with WinSCP :
        • For the boot you can edit the file /recalbox/system/resources/splash/recalboxintro.srt and put an empty space instead of the version number.
        • for games launch, you can delete the file /recalbox/system/resources/splash/logo-version.png , and duplicate the file logo.png with the name logo-version.png.
        Thoses changes will be erased when you do an update, so you have to edit files again.
        Aaron Stevenson 1 Reply Last reply Reply Quote 1
        • Aaron Stevenson
          Aaron Stevenson @idarius last edited by Aaron Stevenson
          @idarius You're awesome. Thanks so much!
          Just to make this solution more complete, I had to make the system partition writable in WinSCP before this solution worked.
          See here: https://github.com/recalbox/recalbox-os/wiki/Make-a-partition-writable-(EN)
          • idarius
            i saw this on some posts here 2 days ago 😉 glad you're happy with that !
            • Erickson Gutierrez
              Erickson Gutierrez last edited by
              what is going on? It seems the codes aren't working here after update =(
              Can someone help?
                rockaddicted @Erickson Gutierrez last edited by
                @erickson-gutierrez you are on official recalbox forum, we don't do support on other forks.
                Erickson Gutierrez 1 Reply Last reply Reply Quote 0
                  Erickson Gutierrez @rockaddicted last edited by
                  @rockaddicted i understand but i'm just asking if somebody can help. Does anyone imagine what would be the problem?
                    @erickson-gutierrez your screenshot show a script that is not present in stock recalbox.
                    So you are not using recalboxOS.
                    If you want support, use the forum of the fork that you are using.
                    Thank you.
