    [4.1] - bluetooth problems
    Testers's corner
    [4.1] bluetooth
    7456
      Issue: https://gitlab.com/recalbox/recalbox/issues/206
      branch: https://review-206-4-1-bt-v1n6em-archive-prod.recalbox.com
      To test, edit recalbox.conf and set updates.type to eh branch name above :
      updates.type=https://review-206-4-1-bt-v1n6em-archive-prod.recalbox.com
        For now, I need feedback from ~/logs/ recalbox.log. The branch logs better what happens on pairing
        • Kiwi41
          Kiwi41 last edited by
          [ 0,00] ---- recalbox-config.sh ----
          [ 0,00] Unpairing and removing BT device CC:C5:0A:07:89:CA
          [ 0,00] pairing Carrefour CC:C5:0A:07:89:CA
          [ 0,00] 8Bitdo detected
          [ 0,00] adding rule for CC:C5:0A:07:89:CA
          [ 0,00] bluetooth : CC:C5:0A:07:89:CA failed connection
            Substring @Kiwi41 last edited by Substring
            @kiwi41despite that's not the expected output, you showed me a bug that has almost nothing to do with the topic ^^
            Jean-Louis Arnal OyyoDams 2 Replies Last reply Reply Quote 0
            • Jean-Louis Arnal
              Jean-Louis Arnal @Substring last edited by
              The timestamp always at [0,00] ?
                OyyoDams Staff @Substring last edited by
                @substring just my 2 cents: are you sure it's a real bug on Recalbox side, or just a pairing issue on the 8bitdo controller as we've mentionned in the forum ? (Users have to unpair it first, or reset it).
                  Substring @OyyoDams last edited by
                  @oyyodams I wish I knew ... As I don't own a 8bitdo pad, I can't test on my own. But I do believe there is a part of a misuse from people not being able to properly reset their device. Any BT device I tried would work (sometimes after a reboot)
                    @substring I've updated the 8bitdo wiki page with different reset methods I've found from 8bitdo documentation. Feel free to share it over the forum and see it it helps users 🙂
                    Substring 1 Reply Last reply Reply Quote 1
                      @oyyodams D**n, your comments are too long to fit in a new colmn of the table 😕
                        @substring well I'll try to summarize
                          @substring better like that ? 🙂
                          Substring paradadf 2 Replies Last reply Reply Quote 0
                            @oyyodams NIIIIIIIIIIIIIIIICE !!!
                              paradadf Staff @OyyoDams last edited by
                              @oyyodams thanks for your work!
                              But I’m confused with the bluetooth pairing and the start mode. Isn’t that the same? After reseting my controller, Injust need to use the start mode and I’m good to go.
                                OyyoDams Staff @paradadf last edited by
                                @paradadf Thanks! About your question... I don't really know how start mode really works, and if it's really different for each controller. The 8bitdo doc is very confused. My Nes30 Pro controllers don't need any special start mode, so I can't make any test.
                                About other controllers... It seems, but I'm not sure, that some controllers need special start mode. But I don't know if it's for pairing only, or needed each time you turn them on.
                                  @oyyodams I believe what you understood for Bluetooth Pairing were the instructions of holding down the Power ON Combo for, let’s say 1 or three seconds. And the Start Mode is what they call Power On.
                                    17.11.02 embeds the modifications tested, i'm locking
