    Moonlight not creating mapping files to PS3 bluetooth controller
    Emulator Arcade/PC/Console
    moonlight creating mapping ps3 bluetooth
    8081
    • nwildner
      nwildner last edited by
      Sup folks.
      I did all the setup involved to pair my Recalbox(4.1) with my PC using Moonlight. Pairing went smooth, and all games got detected.
      However, when i try to launch any game or Steam app, it launches and terminates a few seconds after launching. No response on my pc screen. Taking a look at the log file /recalbox/share/system/logs/es_launch_stderr.log i can find the following information:
      Traceback (most recent call last):
        File "/work/output/target/usr/lib/python2.7/site-packages/configgen/emulatorlauncher.py", line 210, in <module>
      exitcode = main(args)
        File "/work/output/target/usr/lib/python2.7/site-packages/configgen/emulatorlauncher.py", line 139, in main
      command = generators[system.config['emulator']].generate(system, args.rom, playersControllers)
        File "/usr/lib/python2.7/site-packages/configgen/generators/moonlight/moonlightGenerator.py", line 14, in generate
      config = moonlightControllers.writeControllersConfig(system, rom, playersControllers)
        File "/usr/lib/python2.7/site-packages/configgen/generators/moonlight/moonlightControllers.py", line 45, in writeControllersConfig
      os.remove(confFile)
      OSError: [Errno 2] No such file or directory: '/recalbox/share/system/configs/moonlight/mappingP1.conf'
      It seems that mappingP1.conf is not generated "on-the-fly", neither mapping.conf that is declared at Moonlight.sh script does exists inside /recalbox/share/system/configs/moonlight
      Any tips on how to debug further this issue, or how to manually generate those files. I'm using a PS3 bluetooth clone(shanwan) controller.
      PT_BR Retrogaming on Telegram
        Substring @nwildner last edited by
        @nwildner Hi !
        I've did quite some testing with moonlight during the unstable and never had this problem. The mappingPx.conf files are generated before starting moonlight. So, I'm a little clueless here ...
        In the es_launch_stdout.log you should see a line invoking emulatorlauncher.pyc, can you paste it here please ?
        nwildner 1 Reply Last reply Reply Quote 0
        • nwildner
          nwildner @Substring last edited by
          Hi @substring !
          When i get back home from work i'll do it.
          At the time of Recalbox 4.1 unstable i was an avid user of other RetroGaming solution so, i could not help with testing.
          • nwildner
            nwildner last edited by nwildner
            @Substring . The log is empty. I've even cleaned it before launching Steam App at Moonlight:
            > /recalbox/share/system/logs/es_launch_stdout.log
            tail -f /recalbox/share/system/logs/es_launch_stdout.log
            ^C
            Launched after tailing the log. Empty. If i try to cat it due to possible newfile creation, it's empty too:
            cat /recalbox/share/system/logs/es_launch_stdout.log
            Error message remains the same. Contents after trying to execute any Moonlight app:
            ls -l /recalbox/share/system/logs/es_launch_stderr.log
            -rw-r--r--    1 root     root           852 Oct 18 19:23 /recalbox/share/system/logs/es_launch_stderr.log
            cat /recalbox/share/system/logs/es_launch_stderr.log
                os.remove(confFile)
            Anything else I could try?
            Thanks for the assist.
            edit: Tried a wired controller, still the same.
              @nwildner bug found, corrected on my side, will be in the next release
              • nwildner
                Ok. I'll wait.
                If you have any workaround, or anything i could additionaly test, just ping me 🙂
                sevenx 1 Reply Last reply Reply Quote 0
                • sevenx
                  sevenx @nwildner last edited by sevenx
                  @nwildner
                  Workaround:
                  • Connect over SSH
                  • mount -o remount, rw /
                  • touch /recalbox/share/system/configs/moonlight/mappingP1.conf
                  • touch /recalbox/share/system/configs/moonlight/mappingP2.conf
                  • touch /recalbox/share/system/configs/moonlight/mappingP3.conf
                  • touch /recalbox/share/system/configs/moonlight/mappingP4.conf
                  • touch /recalbox/share/system/configs/moonlight/mappingP5.conf
                  • et voilà
                  Cthulhus 1 Reply Last reply Reply Quote 1
                  • nwildner
                    hi @sevenx
                    Did that, but instead just symlinked all (p2 to p5) to p1.conf 🙂
                    Worked like a charm. Thanks for all the help.
                    • sevenx
                      @nwildner do you tested the Steam Big Picture mode?
                      • nwildner
                        nwildner @sevenx last edited by nwildner
                        @sevenx Yup.
                        It is how the default Steam app behaves: It open using big picture mode.
                        It is working, with 2 controllers paired both can navigate at the menus, however, I've faced some lag while browsing through the games, but that is another problem. Maybe i will need to buy a 5GHz Wireless NIC to my pc(Rpi3 is cabled to the router). But if i reduce quality to 720p and 30fps at the configuration, gameplay goes smooth.
                        I can even play PSX2 games that are not theoretically optimized to use the Nvidia streaming protocol.
                        And this is a big point to Recalbox: It recognized and added this psx2 bat i have on Windows as a game inside Moonlight menu 🙂
                        Substring sevenx 2 Replies Last reply Reply Quote 1
                          @nwildner Wow that's some nice "setup" here 🙂 Give a try to CEmu and RPCS3 through Moonlight haha
                          • sevenx
                            @nwildner What controllers are you using?
                            • nwildner
                              @sevenx PS3 Bluetooth clone, shanwan chipset.
                              @Substring Don't know how ps3 games will behave. I have the minimum recommended GPU(GTX 650). I'll give it a try 😛
                              • Gaetan
                                Gaetan Theme moderator last edited by
                                Hi!
                                No one is having issues while pressing the joystick to run in a fps and it's not working ?
                                Could you show the mappingP1.conf that you are using ?
                                Thank you very much!
                                Gaetan nwildner 2 Replies Last reply Reply Quote 0
                                • Gaetan
                                  Gaetan Theme moderator @Gaetan last edited by
                                  @gaetan Probleme solved, I remapped my controler and everything is fine
                                  • nwildner
                                    nwildner @Gaetan last edited by
                                    Hi @gaetan
                                    I've just created an empty file using touch command as explained by sevenx. This was enough to make moonlight work, and the mapping used is still the default already set at Emulationstation
                                    • Cthulhus
                                      Cthulhus @sevenx last edited by Cthulhus
                                      @sevenx said in Moonlight not creating mapping files to PS3 bluetooth controller:
                                      Workaround
                                      Thanks for the Workaround!
                                      One question :
                                      I'm using a wireless keyboard and mouse on my Recalbox (nice for IBM and Scummvm's games) does it can work too for the Moonlight and be able to play games like Total Wars ?
                                      If I delete all : mappingP1.conf to mappingP5.conf, the keyboard + mouse work fine.
                                      If I have mappingP1.conf to mappingP5.conf, no mouse and keyboard but working controlers.
                                      I think that I can't have all 🙂 Le beurre et l'argent du beurre et le ... 🙂
                                      C'était mieux avant :-)
                                      • nwildner
                                        nwildner @Cthulhus last edited by nwildner
                                        @cthulhus
                                        Have you tried yesterday's update?(Recalbox 17.11.02)
                                        This manual creation of mappingP1-5.conf was a workaround, and it is possible that the patch created by @Substring solved the issue: Moonlight now finally runs without crashing at start
                                        Cthulhus Substring 2 Replies Last reply Reply Quote 0
                                        • Cthulhus
                                          Cthulhus @nwildner last edited by
                                          @nwildner yep, the today's patch fixe the issue !
                                            @nwildner i solved the Moonlight issue (as i made the issue myself). You reported it, we promised we'd make much more updates after 4.1, here is the proof 🙂
