    High bluetooth latency on 8bitdo controller
    GamePad/GPIO/USB encoder
    high bluetooth latency 8bitdo
    4789
    • ignign0kt
      ignign0kt last edited by
      I'm using a NES30Pro and the bluetooth latency is all over the place and makes games unplayable. Latency is fine when plugged in with USB.
      I've tried it with the onboard bluetooth, and then with a USB dongle.
      However I did not disable the onboard bluetooth when the dongle was in. How can I do that to see if that makes a difference? I tried setting the "controllers.bluetooth.enabled=0" in the conf but then the USB dongle didn't work either.
      • idarius
        idarius last edited by idarius
        Hi,
        The first bluetooth used is the USB dongle, before internal bluetooth in all case.
        I think there is a line in boot.txt for disable the internal (saw that in a post from @Substring), but it is not needed.
        Are you in 4.1 ?
        What is your usb dongle ?
        Are your Nes30pro firmware up to date ?
        idarius
        ignign0kt 1 Reply Last reply Reply Quote 0
          Substring @ignign0kt last edited by
          @ignign0kt You need to add an overlay to disable the onboard BT on a pi3. Anyway, if you plug a dongle, this will be the main BT adapter
          • ignign0kt
            ignign0kt @idarius last edited by
            @idarius Yeah I'm on 4.1, using a SoundBot SB340, and newest 8bitdo firmware.
            Not sure what else to try.
            The only thing I've left to try is to use an pre-2.0 8bitdo firmware because if I recall correctly the latency wasn't as bad as it is now
            @Substring Ah ok, as long as the onboard wouldn't interfere with the performance of the dongle than I won't bother disabling it.
              @ignign0kt said in High bluetooth latency on 8bitdo controller:
              well, I can't say
              • ignign0kt
                ignign0kt @Substring last edited by
                @substring I did try the dtoverlay to disable, but that didn't work -- bluetooth is still on
                I did notice/realize though that I'm on 4.1.0-DEV. If that could have any impact, is there a way to "upgrade" to the stable 4.1 without re-installing from scratch?
                  @ignign0kt please read the 4.1.0 FAQ on the forum
                  • ignign0kt
                    ignign0kt last edited by ignign0kt
                    I reinstalled 4.1 stable and now my USB dongle isn't working at all ;
                    Just says working for 5-10 seconds and doesn't find anything
                    edit: when i add the dtoverlay to the config file, the dongle doesn't work either. I'm guessing that disables BT system wide and not just the onboard BT?
                    Anyway the latency after installing the stable release is more acceptable now.
                    Thanks
                      OyyoDams Staff @ignign0kt last edited by
                      Hi @ignign0kt,
                      I have a very, very old BT dongle (can't remember the reference) which was working with Recalbox 4.0.2. This dongle doesn't work at all with version 4.1, for an unknown reason. I can see it, but no joystick can be associated with this dongle anymore. Anyway even if my pads can be associated with the internal BT of my RPI 3, I've juste purchased a new CLS BT dongle 4.0, and this one works very well.
                      Just my 2 cents to say that some old BT dongles don't work with Recalbox 4.1 😉
