    PC Specs
    specs
    • didifart
      didifart last edited by
      Hi,
      Congratulation for this new version.
      The fact that it can be installed on a PC is a great improvement.
      Do you have the minimum PC specs that can run smooth on all emulators (N64 and PSP dreamcast)
      Thanks in advance
        Substring @didifart last edited by
        @didifart We can only say "CPU and GPU must be supported by the kernel" + "GPU must be abloe of OpenGL 3.1 at least". There is a newborn wiki at https://github.com/recalbox/recalbox-os/wiki/PC-compatibility-(EN) that is open ofr contributions
        didifart 1 Reply Last reply Reply Quote 1
        • didifart
          didifart @Substring last edited by
          @substring Thanks! Will do some testing then.
