    Xiaomi Bluetooth Wireless Gamepad and Recalbox 4.1.0
    GamePad/GPIO/USB encoder
    xiaomi bluetooth wireless gamepad recalbox
    6
    7
    3674
    • pyrrhic
      pyrrhic last edited by
      Hi,
      I installed Recalbox 4.1.0 yesterday on a Raspberry Pi 3. I'm having trouble getting it to pair with my Xiaomi Bluetooth Wireless Gamepad. I've seen this here:
      https://github.com/recalbox/recalbox-os/issues/1220
      Which seems to indicate any issues with this pad should have been solved with 4.1.0. Can anyone else confirm? Is there something special I need to do that i'm not?
      When I try to pair, the controller shows up - and the name is indeed a load of Chinese characters, which someone in the thread above seemed to suggest may have been a problem. When I click to pair, it simply fails.
      Aside: I actually was previously using Recalbox 4.0 on a pi 2 with a generic bluetooth dongle - I had this pad working well, but just the once - on subsequent occasions when I tried to pair it again it would fail. This was one of the reasons I upgraded!
      All suggestions welcome! Thanks.
        Substring @pyrrhic last edited by
        @pyrrhic Hi
        This darn pad uses Bluetooth 3.0 which should have been erradicated long ago 😄
        So, you'll need to add controllers.bluetooth.alternate=1 to your recalbox.conf file otherwise your pad will NEVER reconnect after a reboot.
        Regarding the bluetooth pairing issue, forget known pads, reboot, try again, and again. If it's still a problem, try https://github.com/recalbox/recalbox-os/wiki/Connect-bluetooth-controller-manually-(EN)#if-your-recalbox-version-is-41x-or-later
        • pyrrhic
          pyrrhic last edited by pyrrhic
          Hi Substring,
          Thanks for replying - I was going to try and message you on github seeing as you seemed to know about it, but decided to just try these forums in the end.
          Thanks, that's great - will do, and I'l report back. I hope I can get it working - I have an old ps3 controller that I can use if not, but the Xaomi pad is a really nice controller, outdated bluetooth aside - although the ps3's rather flabbier and imprecise feeling analogue sticks do make the N64 games that bit more 'authentic' 🙂
          • retrobit
            retrobit last edited by retrobit
            @Substring @pyrrhic
            Hi!
            In my case I hadn't no trouble pairing it. It worked for me using "short press" (slow blink) pairing button. After adding controllers.bluetooth.alternate=1 to recalbox.conf it seems to work using "long press" (fast blink) button way. Anyway, it seems to work perfectly for me except for Kodi.
            In my case, the only trouble I have is using Kodi. It doesn't seem to respond to Xiaomi Controller, so I use Virtual Pad. In that case Virtual Pad only works if Xiaomi Controller has not been paired in first place.
            I'm using:
            -Rasperry Pi 2
            -CSL - V4.0 USB nano
            -Xiaomi Controller
            -Sandisk Ultra Fit 128GB USB 3.0
            -Recalbox 4.1 fresh install
            Thanks for your time and sorry about my English.
            Cheers.
            • idarius
              idarius last edited by
              Hi, last time i check with my xiaomi controller, the pairing was fine, but if i idle in a game until the gamepad disconnect, it was impossible to repair it in game. needed to restart the pi in for my controller to come back.
              • Click Vzoo
                Click Vzoo Banned last edited by
                This post is deleted!
                • swami11
                  swami11 Banned last edited by
