    4.1 Mame scraping doesn't save
    4.1 mame scraping doesnt
    2885
    • sibobbbe
      sibobbbe last edited by sibobbbe
      It finds every ROM perfectly, with great images, for all systems (what a relief after thegamesdb.net scraper!) but on every reboot, it resets back to a list and seems to have lost all the scrape data for Mame. edit - NES too.
      I get a warning when scraping that "Some of your selected systems do not have a platform set" But I don't know what it means, everything does seem set up right, and was before 4.1!
      Any ideas? Thanks
        Substring @sibobbbe last edited by
        @sibobbbe are you using a USB key ?
        sibobbbe 1 Reply Last reply Reply Quote 0
        • sibobbbe
          sibobbbe @Substring last edited by
          @substring Thanks for your reply. I'm not using a USB key.
          I solved it, finally. Turns out EmulationStation doesn't save data to gamelists if you restart after scraping. I have to fully shut down the system for it to save the data.
          Is this just for me? I tried it on a brand new installation and it was the same case, but I haven't seen this mentioned anywhere else, which I found strange since it's such an easy issue to replicate.
            @sibobbbe If you're using the fast shutdown, it doesn't save metadata, indeed. That's why there is a warning.
            • sibobbbe
              sibobbbe @Substring last edited by sibobbbe
              @substring It was restart, not fast shutdown, but I guess it must be the same thing.
              Oh I see the warning is on 'fast shutdown', which I'd never done before. It should be on restart because the same applies.
                @sibobbbe no ! restart saves the metadata
