    ODROID-XU4 vs ODROID C2 vs Raspberry Pi 3
    odroid-xu4 odroid
    10
    48
    31886
    • Backpaddle
      Backpaddle @Substring last edited by
      @substring i know that single games can make problems, so its ok, thank you
      • patriccote
        patriccote last edited by
        @Substring Thanks for the test, it now seems like the perfect solution ! Question, what was the size of the movie you have tested ?
        I will still wait from @Dragu and @abunille tests before buying a ODROID-XU4. If anybody else using this board have tested high definition 1080p (5.1, 7.1) movies under Recalbox 4.1.0 / Kodi 16, please tell me !
        Thanks !
        patriccote
        Substring abunille 2 Replies Last reply Reply Quote 0
          Substring @patriccote last edited by
          @patriccote The file was 9.4GB, 1920x1072 H264 High profile, DTS 5.1
          • patriccote
            @Substring This is the kind of file I use so if you report no lag watsoever, it's good for me !
            If anybody else wants to add the result of their own tests, it would be great !
            patriccote
              @patriccote I wasn't on a TV to compare and say "it does work perfectly". It looked fine, can't tell much more, i haven't spent that much time with it. I don't even know where to find the h/w acceleration info in Kodi
              • patriccote
                @Substring As I understand, since ODROID-XU4 does not have hardware acceleration, Kodi should run in 'software' mode by default. I don't think you have to find the "hardware acceleration" option to do a good test.
                For your information, you can find the option somewhere under "System" - "Playback" ...
                Thanks !
                patriccote
                • Dragu
                  Dragu Banned last edited by
                  @patriccote
                  I have no Xu4 yet, but there seems to be some sound quality issues, just what I heard. Because Xu4 has no i2s interface as Raspberry has, so no direct DAC sound possibility.
                  • patriccote
                    @Dragu I use my Raspberry Pi 2 as a home Entertainment center, plugged in my Yamaha receiver using the HDMI cable and the receiver decode the AC-3 / DTS signal through the "bypass" command of Kodi. I cannot bypass DTS-ES / DTS-HD with my Rpi2 / Kodi 15 but I can with a Western Digital "WD TV Live".
                    • Do you think I will have problems bypassing sound to my receiver ?
                    • Note that I know nothing about the i2s interface / direct DAC, can you explain this to me ?
                    Thanks !
                    patriccote
                    • Dragu
                      @patriccote
                      You find a lot of informations on the web, its named Integrated Interchip Sound (IIS) therefore I2S. It use an own serial bus not dependant from the uP clock. So better digital sound. But the problem is different. If you want to make a DAC, DAC chips recuperate this signal, and when the board is not producing this sound signal, no DAC. They use pulse audio and that not the best quality. So up to you to know if Kodi is important.
                        No pulse audio on recalbox, just plain alsa. I've never plugged my xu4 on my home cinema though
                        • Dragu
                          Tinkerboard also no i2s, but planned. Honestly, for me the PI3 is for the moment perfect. And the games that he cannot run are mostly no retrogames and often illegal 😉 . And if PI4 comes out, I have time to look after the latest.
                          • abunille
                            abunille @patriccote last edited by
                            @patriccote
                            I had only an 1920x800 file here to test. 9.8GB with DTS 5.1.
                            Dont see issues
                            • patriccote
                              Thanks everybody for the info. I know RPI3 will work perfectly but when I tried Marvel VS Captom 2 (Dreamcast version), it was a bit laggy. Really playable but not constant 30fps ... maybe the settings, maybe the power of the RPI3. That's why I'm looking for a ODROID-XU4 but if I have other issues that I don't have with my RPI2 / RPI3, I might not go that way. That's why I wanted feedback with people who played a lot of movies on the ODROID-XU4 to see if issues occured.
                              Thanks !
                              patriccote
                              • MarcDK
                                MarcDK last edited by
                                After I compared Soul Calibur with Reicast on my Raspberry Pi 3 with the original game on hardware, I saw a striking difference between the two: the shadows are abstinent on recalbox.
                                Can someone confirm that the shadows are missing on odroid, too?
                                https://marc.tv
                                  voljega Banned @MarcDK last edited by
                                  @marcdk well the shadows are keeping themselves pure for marriage I guess 😢
                                  • MarcDK
                                    So there is no option in Recalbox to display them properly? Even on odroid? The game look bland with the shadows.
                                    https://marc.tv
                                    • MarcDK
                                      @substring Could you tell me what I need for my recalbox / odroid setup?
                                      • Odroid XU4 mainboard
                                      • Power Supply Cable
                                      • XU4 Case
                                      • 16Gb eMMC
                                      Does it have support for a normal micro SD card? Ist the eMMC for the recalbox os and I can put the roms on my existing micro sd card with 64 gb?
                                      https://marc.tv
                                        Substring @MarcDK last edited by
                                        @marcdk I can't answer your questions as I don't have an eMMC. I just know it's "complicated" for now when having both at the sametime, it won't boot on the SD. I have an idea why, but can't check.
                                        • MarcDK
                                          it won't boot from the micro sd? But how did you start it if you don't have an eMMC?
                                          https://marc.tv
                                          • MarcDK
                                            @Substring Ah, I understand: you don't use an eMMC but instead only a micro SD card. Ok, that works? I only need to buy an odroid u4, a power supply and that's it?
                                            https://marc.tv
                                            100.2k
