    8BitDo SNES30 Bluetooth Problem
    GamePad/GPIO/USB encoder
    8bitdo snes30 bluetooth
    4506
    • JamieSection23
      JamieSection23 last edited by
      Afternoon all.
      I've tried to pair my new SNES30 (with up to date firmware) to Recalbox. It finds the pad and displays it's address (rather than it's name) but then when selected, Recalbox either crashes totally or carries on as normal but the controller doesn't work unless it's connected with it's USB cable.
      Could anyone help please? I'm a bit new to this!
        Substring @JamieSection23 last edited by
        @jamiesection23 may I suggest you wait for 13th of October ?
        Dragu JamieSection23 2 Replies Last reply Reply Quote 0
        • Dragu
          Dragu Banned @Substring last edited by
          @substring
          Remember 13 and is also a Friday ! 🙂
            Substring @Dragu last edited by
            @dragu yeah, we are pretty confident in our schedule 😄
            • JamieSection23
              JamieSection23 @Substring last edited by
              @substring said in 8BitDo SNES30 Bluetooth Problem:
              Yeah sure, shall do. Thank you for the reply.
              • JamieSection23
                Morning all
                Since applying the update I still can't pair my controller. It just says "controller not found" when I try and do it from the selection menu.
                Does anyone know how to actually do it or is it still not possible?
                Loving the new scraper options - so good!
                akh150 1 Reply Last reply Reply Quote 0
                • akh150
                  akh150 @JamieSection23 last edited by akh150
                  @jamiesection23 hello, what do you have? pi2 /pi 3? which version of recalbox? What is the firmware of your controller?
                  Actually, you just have to hold the power button only for about 3 sec, find your device in the recalbox, then configure it.
                  Try it several times if it doesn't work directly, sometimes this controller can be hard to find.
                  Tell us if it's work.
                  if you understand french, there is a topic on this problem : https://forum.recalbox.com/topic/9380/je-n-arrive-plus-à-appairer-ma-nes-30-pro/89
                  and maybe few more informations in this post : https://forum.recalbox.com/topic/9394/4-1-bluetooth-pairing-persistency-issue/29
                  hope it helps.
                  Upvote si je t'ai aidé 😉
                  JamieSection23 1 Reply Last reply Reply Quote 0
                  • JamieSection23
                    JamieSection23 @akh150 last edited by
                    @akh150 said in 8BitDo SNES30 Bluetooth Problem:
                    hope it helps.
                    I'm using the latest update to Recalbox, my pi is a pi2 and the firmware is the most recent on the controller.
                    I wish I could read French, that would be a great skill. Sadly I can't though.
                    I'll try holding down the power button and see if that helps. Thank you!
                      @jamiesection23 Carefully read the 8bitdo documentation on how to reset your pad (because if the pad has been previously paired with any device, including your Pi, it will fail), and the good way to start it. I have a 8bitdo Zero + NES30 Arcade, both work (I.E. pair, connect and reconnect) great as long as you follow those rules.
                      JamieSection23 1 Reply Last reply Reply Quote 1
                      • JamieSection23
                        @substring Thank you, I'll check that out later also 🙂
