    adblock
    adblock
    2007
    • akadajet
      akadajet last edited by
      Just letting you guys know that if you're going to block me from looking at your store with Adblock I'm not interested in your product at all.
      MikaXII 1 Reply Last reply Reply Quote 1
      • MikaXII
        MikaXII Staff @akadajet last edited by MikaXII
        @akadajet There are absolutely no ads on the recalstore only amazon links because we doesn't sell product we just listing all compatible hardware, and amazon links are automatically blocked by adblock...
        mika@recalbox.com
        akadajet 1 Reply Last reply Reply Quote 0
        • akadajet
          akadajet @MikaXII last edited by
          @mikaxii They aren't with uBlock, at least. I can look at other sites that have Amazon links (with referrer) and they aren't scrubbed.
          For reference, the site I'm looking at is https://www.tonymacx86.com/buyersguide/september/2017/
          MikaXII 1 Reply Last reply Reply Quote 0
          • MikaXII
            @akadajet
            Below, logs of my uBlock origin plugin.
            As you see only link to amazon was blocked (and google analytics/facebook but we don't care about it).
            We use amazon's widget, and that widget are blocked no direct link (I think).
            I repeat we never use ads on all our product (website, recalbox-os, our blog).
            mika@recalbox.com
            rockaddicted akadajet 2 Replies Last reply Reply Quote 0
              rockaddicted @MikaXII last edited by
              @mikaxii said in adblock:
              indeed that is the reason
                Substring @rockaddicted last edited by
                @rockaddicted said in adblock:
                Both @rockaddicted and @MikaXII are right. I also experienced adblock problems with the recalstore because of adblock.
                • akadajet
                  akadajet @MikaXII last edited by akadajet
                  @mikaxii Okay. That makes more sense. With the kind of message you are displaying it's going to look to most people like you are actively punishing them for using an ad blocker. Unfortunately a lot of sites do this.
                  https://www.reddit.com/r/assholedesign/
                  I'd recommend ditching the Amazon widget and just using referrer links for a better experience if it's possible.
                  Sorry about sounding alarmist.
                  • MikaXII
                    @akadajet but I agree with you the message can be more explicit 🙂
                    mika@recalbox.com
