    Solved Confused Over Dos Games
    Emulator Arcade/PC/Console
    confused dos
    10
    126
    66144
    • kaz69
      kaz69 @Dragu last edited by
      @dragu
      Im going to unpack all the files in my folder and then give it another try tonight and let you know how it goes.
      thanks
      • kaz69
        kaz69 @abunille last edited by
        @abunille
        I've had a search for the rom online and the 1993 download is 8mb but the only 1994 one I can see is for the emulator 3DO which is 500mb.
        • kaz69
          kaz69 last edited by
          @Dragu
          Done all the unpacking of the files and copied the install.bat to a dosbox.cfg and it's working, but the problem I have now is that the game screen is tiny and is in the bottom left corner of my tv screen.
          Not sure why but at least one problem sorted now it's getting the screen sorted
          • Dragu
            Dragu Banned last edited by
            @kaz69 said in Confused Over Dos Games:
            dosbox.cfg
            you mean dosbox.bat ?
            You need to have a dosbox.cfg local with the datas corresponding to the screen that you use.
            Like I told you, if you copy and adapt my version from the posted link, more easy.
            kaz69 1 Reply Last reply Reply Quote 0
            • kaz69
              @dragu
              Sorry im probable making things confusing.
              I have the dosbox.bat file as the location for the horde.exe file
              and the dosbox.cfg file I have as all the dos command lines
              @echo off
              if %1!==! goto USAGE
              set COLON=
              :VALIDDRIVE
              if %1 == πŸ˜„ goto INSTALL1
              these command lines I got from the install.bat file that was from the game after I zipped it, and then copy and pasted it to a text file and made it dosbox.cfg
              with the screen details from your link where do I add the fullscreen=true line etc?
              I know you said about copying your command lines from your link but as im new Ive tried but not sure im doing it right
              • Dragu
                @kaz69
                To understand, dosbox.cfg is a local copy of global dosbox.conf that allow you to define local xxxxx.map for local game.
                In the sdl section you should have
                fullscreen=true
                vsync=false
                fullresolution=desktop
                windowresolution=original
                output=texture
                renderer=auto
                autolock=true
                sensitivity=100
                waitonerror=true
                priority=higher,normal
                mapperfile=horde.map
                dosbox section
                language=
                machine=svga_s3
                captures=capture
                memsize=30
                when memory is not enough
                All this things should be adapted.
                • kaz69
                  @dragu
                  Thanks I have finally got it running to full screen and works perfect (well up to the new game screen anyway). I've learnt a lot in this topic and will try my luck at a few other games and see how it goes.
                  sorry for the long time this has taken and repeat information but its all clicked with me now (hopefully)
                  once again thanks Dragu for your time and patience with me
                    voljega Banned @kaz69 last edited by voljega
                    @kaz69 @Dragu
                    Hello Guys, using this unofficial DosBox main thread to ask for your help : it's time for me to try my big next project : doing an automatic convertor of the ExoDOS game collection to Recalbox. The collection uses the same version of DosBox, 0.74
                    So first I would like to do one manually to better understand how to work, and I'm gonna start with one my fav from the nineties : Wacky Wheels.
                    Now first of all, games will be installed either by my convertor or manually on the computer, so there no need to bother with that.
                    Secondly I would like to achieve a non dependant path installation, so I want to be able to specify in dosbox.cfg and dosbox.bat if possible, only relatibe path to the game folder (here WackyWhe.pc). The game should then work exactly the same if it is in /recalbox/share/pc/WackyWhe.pc or /recalbox/share/pc/Race/WackyWhe.pc
                    Is it possible ? It should be I think but I'm not sure where DosBox /EmulationStation is positioned as a folder when it starts
                    a note on the exoDOS collection architecture, after installation games are found like that :
                    in eXoDOS_Collection_v2.0\Games!dos\WackyWhe you will find the dosbox.conf and bat file to launch the game
                    in eXoDOS_Collection_v2.0\Games\WackyWhe are stored the files of the games itself (this folder will be transformed in WackyWhe.pc)
                    So normally i would copy the folder eXoDOS_Collection_v2.0\Games\WackyWhe as WackyWhe.pc and put inside the dosbox.conf file and the dosbox.bat files both copied or based from/on eXoDOS_Collection_v2.0\Games!dos\WackyWhe
                    The dosbox.conf is a regular one, so I will show only the autoexec part :
                    [autoexec]
                    cd ..
                    cd ..
                    mount c .\games\WackyWhe
                    imgmount d .\games\WackyWhe\cd\wackywheels.iso -t cdrom
                    c:
                    cd wacky
                    cls
                    @ww
                    exit
                    Here we can see that the game folder has two children folder, one named cd where the iso of the game is located and one named wacky where the game's installed files are, including main executable ww.exe. We should be able to get rid of the cd.. if we manage to use relative paths ?
                    The bat file (Wacky Wheels (1994).bat) from exoDOSCollection mainly handles installation which will be already done :
                    @echo off
                    @set var=%cd%
                    cd ..
                    cd ..
                    cd ..
                    IF NOT EXIST ".\games\WackyWhe\" goto none
                    ".\dosbox\dosbox.exe" -conf ".\games\!dos\WackyWhe\dosbox.conf" -noconsole -exit
                    del stdout.txt
                    del stderr.txt
                    if exist .\games\CWSDPMI.swp del .\games\CWSDPMI.swp
                    goto end
                    :none
                    cls
                    echo.
                    echo Game has not been installed
                    echo.
                    echo.
                    echo Would you like to install the game?
                    echo.
                    choice
                    if errorlevel = 2 goto no
                    if errorlevel = 1 goto yes
                    :yes
                    cd %VAR%
                    call install.bat
                    goto end
                    :no
                    goto end
                    :end
                    The dosbox command is useless here as it is already done by Recalbox configgen.
                    So to me this correspond to dosbox.bat for recalbox, but as the main executable ww.exe is already launched by the [autoexec] part of the dosbox.conf file, my dosbox.bat should be empty ? Can it be empty ?
                    So my main questions are :
                    • how to clean/modify the autoexec part to only keep relative path to the game folder ?
                    • should the dosbox.cfg [autoexec] keep the execution of the ww.exe file (what does the @ in @ww command mean by the way ?) and my dosbox.bat then be empty ?
                    • or should i remove the call to ww.exe from dosbox.conf and use that in my dosbox.bat file once again using only relative path if possible ?
                    Thank you for your help πŸ™‚
                    • Dragu
                      @voljega
                      "The game should then work exactly the same if it is in /recalbox/share/pc/WackyWhe.pc or /recalbox/share/pc/Race/WackyWhe.pc"
                      Dosbox awaits the game directory .pc in /recalbox/share/roms/dos/ xxxxx.pc
                      So, I am not sure that you can change this. I never tried (you will πŸ˜‰ ) if you put the game start in the autoexec section of dosbox.cfg and nothing in dosbox.bat, if this works. But I can try this out. My experience, if nothing in dosbox.bat, he enter the dosbox prompt.
                      • Dragu
                        I just tried it out, it dont work for me with game start in dosbox.cfg (local .conv) and empty dosbox.bat.
                          voljega Banned @Dragu last edited by
                          @dragu "Dosbox awaits the game directory .pc in /recalbox/share/roms/dos/ xxxxx.pc"
                          Dosbox or EmulationStation ?
                          And regarding handling of relative path in dosbox.cfg and dosbox.bat, is dosbox start directory the same as inside xxx.pc or /recalbox/share/dos ?
                          • Dragu
                            Important in all this, ES mount πŸ˜„ as local game directory. I suppose that it is ES.
                            If you mount a virtual CD-ROM, in dosbox.cfg Autoexec section it's about
                            imgmount d "/recalbox/share/roms/dos/abcd.pc/abcd.DAT" -t iso
                            But anyway, who cares ?
                            voljega 2 Replies Last reply Reply Quote 0
                              @dragu who cares ? me πŸ™‚
                              according to this post, it should be perfectly possible to use relative path in dosbox.bat at least :
                              https://forum.recalbox.com/topic/9178/aide-avec-le-ms-dos
                              so if πŸ˜„ is mounted by default on local directory, it might also be used in dosbox.cfg AutoExec part I'll have to test
                              "My experience, if nothing in dosbox.bat, he enter the dosbox prompt."
                              Is it an interactive dos prompt ? it might come handy for testing and debugging.
                              I checked configgen and see nothing which could prevent the use of subdirectories, I will check es_systems.cfg
                                voljega Banned @Dragu last edited by voljega
                                @dragu managed to make anything work relatively by moving the whole [AutoExec] code to dosbox.bat :
                                imgmount d .\cd\wackywheels.iso -t cdrom
                                c:
                                cd WACKY
                                WW.EXE
                                so that's it πŸ™‚
                                But just creating a Race folder and putting WackyWhe.pc into it makes ES crash at boot ! and thus Recalbox doesn't start... @substring ?
                                On a further notice the game seems to allow the use of joystick but i wasn't able to change to it and only A button seems to work. I didn't use any map file
                                EDIT : doesn't work in Windows either so let's say it's a bug, i'll try with Tyrian
                                But one strange thing is that on Recalbox, game isn't displayed on original ratio (4/3) nor fullscreen, it's between the two with borders but a little bit scretched on the horizontal ? Did you notice that ?
                                  Substring @voljega last edited by
                                  @voljega I plead not guilty your honor ...
                                  No idea, hardly ever tried dosbox, not time to check for now πŸ˜•
                                  Ex dev - Merci de me rΓ©pondre en utilisant @substring pour que je sois notifΓ©
                                  • Dragu
                                    @voljega
                                    With my games, for the moment nothing scretched. Also because of your crash at boot. There may be some things to adapt in local dosbox.cfg. Do you looked inside my dosbox.cfg of the above link ? Memory could be a problem. I changed it from dosbox.conf.
                                    And CD Wacky ? Should it not be CD Wacky.pc ?
                                      @dragu The crash at boot is only because of the presence of a *.pc folder into another subfolder (instead of plain /recalbox/share/roms/dos) it doesn't crash as soon as i remove the *.pc folder from the subfolder and leave it at /recalbox/share/roms/dos
                                      Now with original dosbox.conf file of the game, even without the autoexec part, yes it crashes and I had to use your file (the lba one you gave me a while ago wihtout the autoexec part off course), i don't know why but comparing them there are several differences
                                      yours : https://pastebin.com/NFM7uX51
                                      mine : https://pastebin.com/2sGm8u6X
                                      at least output=overlay instead of texture raises a warning in dosbox when launched from command line
                                      "And CD Wacky ? Should it not be CD Wacky.pc ?"
                                      No because when in dosbox.bat . is already setted into the game folder, just like πŸ˜„ , here WackyWhe.pc
                                      so imgmount d .\cd\wackywheels.iso -t cdrom directly mount the iso located there /recalbox/share/roms/dos/WackyWe.pc/cd/wackywheels.iso
                                      And there is a message regarding the mounting at the beginning (after the dosbox orange green) which show that the path is indeed the good one like "Mounted d on /recalbox/share/roms/dos/WackyWe.pc/cd/wackywheels.iso"
                                      and cd WACKY goes from /recalbox/share/roms/dos/WackyWe.pc to /recalbox/share/roms/dos/WackyWe.pc/WACKY folder where ww.exe is located
                                      at the root of my game folder i only have the cfg file and the bat file
                                      Now for ratio comparison we can clearly see the difference especially on the Apogee Moon in the logo which is clearly not round but elliptic on Recalbox : (up real 4/3 dosbox on windows, down something between 4/3 and 16/9 dosbox on recalbox)
                                      https://imgur.com/a/YbdSe
                                      This is again with your dosbox.cfg (but i have a same result on another game without any dosbox.cfg in game folder), the vertical black bars on both side should be twice as wide
                                      OK your file had just aspect=false with aspect=true I get the correct 4/3
                                      I assumed you got your file from the dosbox root folder and this is more or less the one used by default so this might be a bug for 4.1
                                        voljega Banned @voljega last edited by voljega
                                        @voljega Tested Tyrian, joystick works but there is a deadzone problem, the ship goes toward the right by itself, is that configurable in the mapper file ?
                                        By the way, @dragu do you have a sample mapper file ?
                                        Dragu voljega 2 Replies Last reply Reply Quote 0
                                          voljega Banned @Substring last edited by
                                          @substring ah ah ok, so @rockaddicted maybe ?
                                          In the dosbox rom folder, just creating a subfolder Race folder inside and putting WackyWhe.pc game folder into it (that's /recalbox/share/roms/race/WackyWhe.pc) makes ES crash at boot ! and thus Recalbox doesn't even start...
                                          I assume this is a bug in ES ? Maybe this is also the case for scummvm ?
                                          • Dragu
                                            Dragu Banned @voljega last edited by Dragu
                                            @voljega said in Confused Over Dos Games:
                                            @voljega
                                            On the moon, you are right. By the way, if you look from the side....
                                            Just kidding, thanks.
                                            For the mapperfile, you can create by yourself. Just Ctrl+F1 in started game. The mapper is really good. But sometimes I make adaption with edit in the files.
                                            Duke Nukem is now hudger as before, but looks a little like the Donald.
                                            100.2k
                                            Copyright Β© 2021 recalbox.com
