    Solved Confused Over Dos Games
    Emulator Arcade/PC/Console
    confused dos
    10
    126
    64263
      voljega Banned @Dragu last edited by
      @dragu ahah yeah there is a little resemblance.
      Cool for the mapperfile thank you I will try it
      I tried ultima underworld too, works fine.
      By the way, any way to display the fps counter inside DosBox ?
      • Dragu
        Dragu Banned last edited by
        @voljega
        I don't think so, we are not in Steam 🙂
        I was starting to make DN Manhattan working, but before Windows95 should be ready. There I have still some problems. Time will bring the answer. Seems pervert to run windows in Recalbox, but some early games require 95.
          @dragu Perverted I don't know but that would be a feat.
          I also plan to try later to convert some games From ExoWin3.1 collection which run under Dosbox
          • Dragu
            @voljega
            I read the aspect story back in the dosbox Wiki, as I found that it has only an effect on some games.
            aspect = true | false
            Do aspect correction. It only affects non-square pixel modes like VGA Mode 13h, which has a resolution of 320x200 pixels and is used by many DOS games (DOOM, etc). Recommended as such games were designed for 4:3 displays, and without aspect correction will look distorted and not as the developer intended.
            Default is false.
            So, if you have 640x480 or bigger resolution, no need.
              voljega Banned @Dragu last edited by voljega
              @dragu cool to know but then better leave it to true as it will no effect on games with bigger resolution ?
              Dragu 1 Reply Last reply Reply Quote 0
              • Dragu
                Dragu Banned @voljega last edited by Dragu
                @voljega
                I am not sure, because it is also written :
                aspect: Do aspect correction, if your output method doesn't support scaling this can slow things down!.
                So, it seems to have perhaps negative effect on speed. This could be an issue in more recent games.
                  rockaddicted @voljega last edited by
                  @voljega said in Confused Over Dos Games:
                  @substring ah ah ok, so @rockaddicted maybe ?
                  Sorry dude I didn't have time to test this emulator, can't help you.
                    voljega Banned @rockaddicted last edited by
                    @rockaddicted It's not related to the emulator, more an Emulation Station problem regarding how it shows folder as a menu item.
                    Any way, i'll file a bug when 4.1 is released and when there will be a new bug tracking system
                      ah ok, indeed I miss read. I'll check that on the current master build.
                        @voljega I tested on 4.1 x86 version with that:
                        # ls /recalbox/share/roms/dos/test/prince.pc/
                        CDUNGEON.DAT  DIGISND1.DAT  EDUNGEON.DAT  GUARD.DAT     IBM_SND1.DAT  INSTALL.PDM   MIDISND1.DAT  PRINCE.EXE    SKEL.DAT      VIZIER.DAT
                        CPALACE.DAT   DIGISND2.DAT  EPALACE.DAT   GUARD1.DAT    IBM_SND2.DAT  KID.DAT       MIDISND2.DAT  PV.DAT        TITLE.DAT     VPALACE.DAT
                        DESKTOPD.CFG  DIGISND3.DAT  FAT.DAT       GUARD2.DAT    INSTALL.EXE   LEVELS.DAT    PRINCE.DAT    SHADOW.DAT    VDUNGEON.DAT  dosbox.bat
                        And I have no problem, game boots fine.
                          @rockaddicted strange.... i wil retry but on my 4.1 ES doesn't show on boot, I tried with a pc game with both dosbox.cfg and dosbox.bat inside he folder
                            @voljega maybe a bug fixed between last unstable and current master.
                            Please test again on next stable release once available.
                            If problem, we'll check that.
                              voljega Banned @voljega last edited by voljega
                              @rockaddicted I don't remember where the log is maybe there will be something in there regarding the crash of ES ?
                              @voljega Tested Tyrian, joystick works but there is a deadzone problem, the ship goes toward the right by itself, is that configurable in the mapper file ?
                              Ok it was more a sensibility/calibrate problem with the joystick drifting by itself.
                              So to fix that you just need to edit dosbox.conf, go into [joystick] part and modify timed=true to timed=false
                                you can restart ES on ssh a check the error message.
                                  @rockaddicted ok worked for me too the real bug seems to be when you have the same *.pc game in /recalbox/share/ros/dos AND in a subfolder of that too, but it isn't very important then
                                    @voljega thanks for feedback
                                      voljega Banned last edited by
                                      @dragu
                                      imgmount d .\cd\wackywheels.iso -t cdrom directly mount the iso located there /recalbox/share/roms/dos/WackyWe.pc/cd/wackywheels.iso
                                      Well I was a little kick because it works with 'real' dos name for the iso but not with full name when the command is accessed from dosbox.bat, I saw by adding the pause command at the end of the command.bat, really usefull.
                                      • if i change the line to imgmount d .\cd\wackyw~1.iso -t cdrom it works
                                      • if i rename the iso to waky.iso imgmount d .\cd\wacky.iso -t cdrom it works
                                      • if i leave like imgmount d .\cd\wackywheels.iso -t cdrom I get the error image is not found
                                      • if i try imgmount d ".\cd\wackywheels.iso" -t cdrom, image is not found either
                                      The game launched nonetheless but this is a bother for automatic converting.
                                      Do you have an idea to adress directly more-than-8-characters names from dosbox.bat ?
                                      Didn't try to put it back in [autoexec] part yet
                                      • Dragu
                                        @voljega
                                        Dosbox is always a 8.3 file naming system, not like DRDOS later. It has just the Microsoft standard.
                                          @dragu so impossible to get more than 8 characters and forced to use ~1 and such ?
                                          (I have seen examples like imgmount d ".\cd\wackywheels.iso" -t cdrom in some dosbox.cfg [autoexec] but I don't think I tested them)
                                            voljega Banned last edited by voljega
                                            @dragu well even more confusing, @Cthulhus discovered that you can even put some dosbox.cfg parameters into dosbox.bat
                                            So the following dosbox.bat:
                                            aspect=true
                                            mapperfile=lba1.map
                                            c:
                                            cd WACKY
                                            pause
                                            WW.EXE
                                            will rightly set the display to 4/3 but the mapper file won't be used if dosbox.cfg is not present with the same parameters
                                            @Cthulhus managed to set some parameters for the cpu and for graphics too
                                            Well maybe it's better to separate the two anyway
                                            On a side note, to finish with iso names having more than 8 characters : it seems to work to specify them in dosbox.cfg [autoexec] with the full name but then you also have to use the full path
                                            And in the mapper with an xbox360 I can configure dpad directions with the internal mapper but the keys are then not working in game
                                            100.1k
