    MSX controller configuration in some ROMS
    Emulator Arcade/PC/Console
    msx roms
    • Fodox
      Fodox last edited by
      Hello,
      I have a Recalbox 4.0.2 with my RPI3.
      I configured MSX bios files as requested and I can play some ROMS without problem (eg. GOONIES), using USB keyboard or controller.
      Other games require particular keys to start: FROGGER needs 1,2,3,4 to choose players/controller type, BREAKER needs A,B,C for same reason. I pressed the keys but nothing happened.
      Is there a way to enable those keys? Is there a config file to configure mapping?
      Thank you
      Fod.
        Hello
        may be help https://forum.recalbox.com/topic/4102/map-2p-start-button-on-1p-arcade
        Fodox 1 Reply Last reply Reply Quote 0
        • gothrek
          gothrek last edited by
          mmm i think that @Fodox talking about the keyboard. Some msx games need to press a key (1, 2, 3 or 4) for start the game.
          I need 2 understand how can use a keyboard in some msx games.
          tks
          • Fodox
            Fodox @acris last edited by
            @acris I'm sorry, doesn't help, the post you linked is about Mame, my problem is with MSX emulator.
            • Fodox
              Hi!
              I'm frustrated: with the 4.1 release, updated from previous 4.0.2, the keyboard magically worked perfectly!
              Now I have updated to 17.11.02 and It doesn't work again... nooooo 😞 !!!
              There will be something in the BlueMSX configuration, It has no sense.
              It seems that keyboard is not recognized, but only with MSX emulator.
              Keyboard is a Logitech mk260 with USB wireless.
              Any ideas?
              Thanks
              Fod.
