    Audio output problem in PC x86 64 bits problem .
    audio output x86 bits
    4231
    • jackalpret
      jackalpret Translator last edited by
      Hi, I'm using recalbox x86 64bits version in desktop computer.
      I have motherboard gigabyte ga-e350n . It has audio output in front and back, and hdmi output.
      I tried with all exits and I haven't sound ... but the computer with ubuntu or windows has audio output correctly.
      What can I check or force to configure audio ? can I do something in console to check and fix it ?
      Best Regards !!!
        Substring @jackalpret last edited by
        @jackalpret Whicch recalbox version are you using ? Have you checked the different audio outputs available in ES sound options ? Setting a new one would just make it ok for the next emulator launch, but not for your current running ES.
        jackalpret 1 Reply Last reply Reply Quote 0
        • jackalpret
          jackalpret Translator @Substring last edited by
          @substring Hi friend !
          The latest 4.1 version for pc.
          Yes, I changed in this menu , but the volumen goes to 0% ... I put upper, but doesnt work.
            @jackalpret then go have a look with alsamixer in commandline
            • jackalpret
              @substring perfect ! I will try in the afternoon when i return to my home 🙂
                @jackalpret That 0% volume is really weird still ... I've already had it myself, can't find the reason why
                I'd be quite interested in knowing which mixer did the trick for you, recalbox is supposed to increase the volume of each mixer ... weird
                • jackalpret
                  I saw that different people has the problem with 0% volume (in ES menu) when have problem with sound card.
                  Maybe If I choose manually the output and reboot it works ...
                  I use the SAME pendrive in notebook and works fine, but the notebook has only 1 audio output.
                    If your build is one from April, last available public unstable release, you must not have last commits about sound switch devices.
                    • jackalpret
                      jackalpret Translator @rockaddicted last edited by
                      @rockaddicted said in Audio output problem in PC x86 64 bits problem .:
                      It's from march 🙂
                      , so, i will try the latest version 😉
