    [Dosbox] Duke Nukem I Simple selection menu
    Emulator Arcade/PC/Console
    duke nukem simple selection
    4661
    • Dragu
      Dragu Banned last edited by acris
      In Duke Nukem I, the 3 episodes are separated as individual .exe files.
      So, to avoid creating different .pc directories, a modified dosbox.bat file.
      After exit from games, the hand comes back to this menu and with key 4 it will exit to ES.
      @echo off
      :menu
      cls
      echo.
      echo.
      echo.
      echo.
      echo.
      echo DUKE NUKEM I
      echo.
      echo 1 = Episode 1 - Shrapnel City
      echo 2 = Episode 2 - Mission: Moonbase
      echo 3 = Episode 3 - Trapped in the Future
      echo.
      echo 4 = Quit
      echo.
      choice /n /c:1234 Make a selection:
      if errorlevel ==4 goto leave
      if errorlevel ==3 goto dn3
      if errorlevel ==2 goto dn2
      if errorlevel ==1 goto dn1
      goto end
      :dn1
      DN1.EXE
      goto menu
      :dn2
      DN2.EXE
      goto menu
      :dn3
      DN3.EXE
      goto menu
      :leave
      exit
      :end
        paradadf Staff @Dragu last edited by
        @dragu you should make a wiki entry with all your tutorials/tips! It would be very helpful for anyone trying to play those games and can easily be found.
        Regardless if you do it or not, thanks for your contributions!
          voljega Banned @paradadf last edited by
          @paradadf @dragu yep I agree 🙂
          Also could you post me somewhere a full copy of your dosbow.conf and dosbox.bat you did for LBA 1 & 2 ?
          This will help me when i try to write a converter from ExoDOS Collection to Recalbox for any dos game as soon as 4.1 is available
          • Dragu
            Wiki, I will first study before writing bulls**t 😉
            @voljega
            For LBA1 and 2, the description for modification is here :
            https://forum.recalbox.com/topic/8215/4-1-dosbox-little-big-adventure-1-and-2
            But based on the files from gog.com. Anyway, there are alot of copies outside without the sound files, very bad. The mounting of the Iso-files is necessary because this games ask for presence of a CD in the drive as license. But fake-drive makes the deal.
              voljega Banned @Dragu last edited by
              @dragu yeah I know but I would like to see the full dosbox bat and conf/cfg ile to compare with exodos line by line
                paradadf Staff @voljega last edited by
                @voljega I saw this the other day... it might serve you as inspiration.
                https://github.com/sduensin/import-eXoDOS
                • Dragu
                  I dont know how to send mails here so for lba1 (lba2 pretty the same)
                  dosbox.bat
                  RELENT.EXE
                  dosbox.cfg (local dosbox.conf)
                  # This is the configuration file for DOSBox 0.74. (Please use the latest version of DOSBox)
                  # Lines starting with a # are comment lines and are ignored by DOSBox.
                  # They are used to (briefly) document the effect of each option.
                  [sdl]
                  #       fullscreen: Start dosbox directly in fullscreen. (Press ALT-Enter to go back)
                  #            vsync: Sync to Vblank IF supported by the output device and renderer (if relevant).
                  #                   It can reduce screen flickering, but it can also result in a slow DOSBox.
                  #   fullresolution: What resolution to use for fullscreen: original, desktop or a fixed size (e.g. 1024x768).
                  #                     Using your monitor's native resolution with aspect=true might give the best results.
                  #                     If you end up with small window on a large screen, try an output different from surface.
                  # windowresolution: Scale the window to this size IF the output device supports hardware scaling.
                  #                     (output=surface does not!)
                  #           output: What video system to use for output.
                  #                   Possible values: surface, texture, texturenb.
                  #         renderer: Choose a renderer driver if output=texture or output=texturenb. Use output=auto for an automatic choice.
                  #                   Possible values: auto, opengl, software.
                  #         autolock: Mouse will automatically lock, if you click on the screen. (Press CTRL-F10 to unlock)
                  #      sensitivity: Mouse sensitivity.
                  #      waitonerror: Wait before closing the console if dosbox has an error.
                  #         priority: Priority levels for dosbox. Second entry behind the comma is for when dosbox is not focused/minimized.
                  #                     pause is only valid for the second entry.
                  #                   Possible values: lowest, lower, normal, higher, highest, pause.
                  #       mapperfile: File used to load/save the key/event mappings from. Resetmapper only works with the default value.
                  fullscreen=true
                  vsync=false
                  fullresolution=desktop
                  windowresolution=original
                  output=texture
                  renderer=auto
                  autolock=true
                  sensitivity=100
                  waitonerror=true
                  priority=higher,normal
                  mapperfile=lba1.map
                  [dosbox]
                  # language: Select another language file.
                  #  machine: The type of machine DOSBox tries to emulate.
                  #           Possible values: hercules, cga, tandy, pcjr, ega, vgaonly, svga_s3, svga_et3000, svga_et4000, svga_paradise, vesa_nolfb, vesa_oldvbe.
                  # captures: Directory where things like wave, midi, screenshot get captured.
                  #  memsize: Amount of memory DOSBox has in megabytes.
                  #             This value is best left at its default to avoid problems with some games,
                  #             though few games might require a higher value.
                  #             There is generally no speed advantage when raising this value.
                  language=
                  machine=svga_s3
                  captures=capture
                  memsize=30
                  [render]
                  # frameskip: How many frames DOSBox skips before drawing one.
                  #    aspect: Do aspect correction, if your output method doesn't support scaling this can slow things down!.
                  #    scaler: Scaler used to enlarge/enhance low resolution modes. If 'forced' is appended,
                  #            then the scaler will be used even if the result might not be desired.
                  #            Possible values: none, normal2x, normal3x, advmame2x, advmame3x, advinterp2x, advinterp3x, hq2x, hq3x, 2xsai, super2xsai, supereagle, tv2x, tv3x, rgb2x, rgb3x, scan2x, scan3x.
                  frameskip=0
                  aspect=false
                  scaler=normal2x
                  [cpu]
                  #      core: CPU Core used in emulation. auto will switch to dynamic if available and
                  #            appropriate.
                  #            Possible values: auto, dynamic, normal, simple.
                  #   cputype: CPU Type used in emulation. auto is the fastest choice.
                  #            Possible values: auto, 386, 386_slow, 486_slow, pentium_slow, 386_prefetch.
                  #    cycles: Amount of instructions DOSBox tries to emulate each millisecond.
                  #            Setting this value too high results in sound dropouts and lags.
                  #            Cycles can be set in 3 ways:
                  #              'auto'          tries to guess what a game needs.
                  #                              It usually works, but can fail for certain games.
                  #              'fixed #number' will set a fixed amount of cycles. This is what you usually
                  #                              need if 'auto' fails (Example: fixed 4000).
                  #              'max'           will allocate as much cycles as your computer is able to
                  #                              handle.
                  #            Possible values: auto, fixed, max.
                  #   cycleup: Amount of cycles to decrease/increase with keycombos.(CTRL-F11/CTRL-F12)
                  # cycledown: Setting it lower than 100 will be a percentage.
                  core=dynamic
                  cputype=auto
                  cycles=max
                  cycleup=100
                  cycledown=100
                  [mixer]
                  #   nosound: Enable silent mode, sound is still emulated though.
                  #      rate: Mixer sample rate, setting any device's rate higher than this will probably lower their sound quality.
                  #            Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.
                  # blocksize: Mixer block size, larger blocks might help sound stuttering but sound will also be more lagged.
                  #            Possible values: 1024, 2048, 4096, 8192, 512, 256.
                  # prebuffer: How many milliseconds of data to keep on top of the blocksize.
                  nosound=false
                  rate=44100
                  blocksize=1024
                  prebuffer=20
                  [midi]
                  #     mpu401: Type of MPU-401 to emulate.
                  #             Possible values: intelligent, uart, none.
                  # mididevice: Device that will receive the MIDI data from MPU-401.
                  #             Possible values: default, win32, alsa, oss, coreaudio, coremidi, none.
                  # midiconfig: Special configuration options for the device driver. This is usually the id of the device you want to use.
                  #               or in the case of coreaudio, you can specify a soundfont here.
                  #               When using a Roland MT-32 rev. 0 as midi output device, some games may require a delay in order to prevent 'buffer overflow' issues.
                  #               In that case, add 'delaysysex', for example: midiconfig=2 delaysysex
                  #               See the README/Manual for more details.
                  mpu401=intelligent
                  mididevice=default
                  midiconfig=
                  [sblaster]
                  #  sbtype: Type of Soundblaster to emulate. gb is Gameblaster.
                  #          Possible values: sb1, sb2, sbpro1, sbpro2, sb16, gb, none.
                  #  sbbase: The IO address of the soundblaster.
                  #          Possible values: 220, 240, 260, 280, 2a0, 2c0, 2e0, 300.
                  #     irq: The IRQ number of the soundblaster.
                  #          Possible values: 7, 5, 3, 9, 10, 11, 12.
                  #     dma: The DMA number of the soundblaster.
                  #          Possible values: 1, 5, 0, 3, 6, 7.
                  #    hdma: The High DMA number of the soundblaster.
                  # sbmixer: Allow the soundblaster mixer to modify the DOSBox mixer.
                  # oplmode: Type of OPL emulation. On 'auto' the mode is determined by sblaster type. All OPL modes are Adlib-compatible, except for 'cms'.
                  #          Possible values: auto, cms, opl2, dualopl2, opl3, opl3gold, none.
                  #  oplemu: Provider for the OPL emulation. compat might provide better quality (see oplrate as well).
                  #          Possible values: default, compat, fast.
                  # oplrate: Sample rate of OPL music emulation. Use 49716 for highest quality (set the mixer rate accordingly).
                  #          Possible values: 44100, 49716, 48000, 32000, 22050, 16000, 11025, 8000.
                  sbtype=sb16
                  sbbase=220
                  irq=7
                  dma=1
                  hdma=5
                  sbmixer=true
                  oplmode=auto
                  oplemu=default
                  oplrate=44100
                  [gus]
                  #      gus: Enable the Gravis Ultrasound emulation.
                  #  gusrate: Sample rate of Ultrasound emulation.
                  #  gusbase: The IO base address of the Gravis Ultrasound.
                  #           Possible values: 240, 220, 260, 280, 2a0, 2c0, 2e0, 300.
                  #   gusirq: The IRQ number of the Gravis Ultrasound.
                  #           Possible values: 5, 3, 7, 9, 10, 11, 12.
                  #   gusdma: The DMA channel of the Gravis Ultrasound.
                  #           Possible values: 3, 0, 1, 5, 6, 7.
                  # ultradir: Path to Ultrasound directory. In this directory
                  #           there should be a MIDI directory that contains
                  #           the patch files for GUS playback. Patch sets used
                  #           with Timidity should work fine.
                  gus=false
                  gusrate=44100
                  gusbase=240
                  gusirq=5
                  gusdma=3
                  ultradir=C:\ULTRASND
                  [speaker]
                  # pcspeaker: Enable PC-Speaker emulation.
                  #    pcrate: Sample rate of the PC-Speaker sound generation.
                  #     tandy: Enable Tandy Sound System emulation. For 'auto', emulation is present only if machine is set to 'tandy'.
                  #            Possible values: auto, on, off.
                  # tandyrate: Sample rate of the Tandy 3-Voice generation.
                  #    disney: Enable Disney Sound Source emulation. (Covox Voice Master and Speech Thing compatible).
                  pcspeaker=true
                  pcrate=44100
                  tandy=auto
                  tandyrate=44100
                  disney=true
                  [joystick]
                  # joysticktype: Type of joystick to emulate: auto (default), none,
                  #               2axis (supports two joysticks),
                  #               4axis (supports one joystick, first joystick used),
                  #               4axis_2 (supports one joystick, second joystick used),
                  #               fcs (Thrustmaster), ch (CH Flightstick).
                  #               none disables joystick emulation.
                  #               auto chooses emulation depending on real joystick(s).
                  #               (Remember to reset dosbox's mapperfile if you saved it earlier)
                  #               Possible values: auto, 2axis, 4axis, 4axis_2, fcs, ch, none.
                  #        timed: enable timed intervals for axis. Experiment with this option, if your joystick drifts (away).
                  #     autofire: continuously fires as long as you keep the button pressed.
                  #       swap34: swap the 3rd and the 4th axis. can be useful for certain joysticks.
                  #   buttonwrap: enable button wrapping at the number of emulated buttons.
                  joysticktype=auto
                  timed=true
                  autofire=false
                  swap34=false
                  buttonwrap=false
                  [serial]
                  # serial1: set type of device connected to com port.
                  #          Can be disabled, dummy, modem, nullmodem, directserial.
                  #          Additional parameters must be in the same line in the form of
                  #          parameter:value. Parameter for all types is irq (optional).
                  #          for directserial: realport (required), rxdelay (optional).
                  #                           (realport:COM1 realport:ttyS0).
                  #          for modem: listenport (optional).
                  #          for nullmodem: server, rxdelay, txdelay, telnet, usedtr,
                  #                         transparent, port, inhsocket (all optional).
                  #          Example: serial1=modem listenport:5000
                  #          Possible values: dummy, disabled, modem, nullmodem, directserial.
                  # serial2: see serial1
                  # serial3: see serial1
                  # serial4: see serial1
                  serial1=dummy
                  serial2=dummy
                  serial3=disabled
                  serial4=disabled
                  [dos]
                  #            xms: Enable XMS support.
                  #            ems: Enable EMS support. The default (=true) provides the best
                  #                 compatibility but certain applications may run better with
                  #                 other choices, or require EMS support to be disabled (=false)
                  #                 to work at all.
                  #                 Possible values: true, emsboard, emm386, false.
                  #            umb: Enable UMB support.
                  # keyboardlayout: Language code of the keyboard layout (or none).
                  xms=true
                  ems=true
                  umb=true
                  keyboardlayout=none
                  [autoexec]
                  # Lines in this section will be run at startup.
                  # You can put your MOUNT lines here.
                  imgmount d "/recalbox/share/roms/dos/lba1.pc/LBA.DAT" -t iso
                  (This editor is a horror)
                    paradadf Staff @Dragu last edited by paradadf
                    @dragu you can read about markdowns here:
                    http://commonmark.org/help/
                    For larger code blocks it is often better to use www.pastebin.com
                    Here your code:
                    https://pastebin.com/iKJ43efP
                      @paradadf@dragu thank you both, i'll have a look at that !
                      • Dragu
                        @paradadf
                        thank you for your great job here !
                        and have a nice day.
