    [Resolved] Display Settings For Games
    [resolved] display settings
    4678
    • tony-black
      tony-black last edited by
      I have a mini 5 inch display which I have to use the following settings in my config.txt for it to work (which I can see the recalbox menu and its all good): # uncomment if hdmi display is not detected and composite is being output hdmi_force_hotplug=1   # uncomment to force a specific HDMI mode (here we are forcing 800x480!) hdmi_group=2 hdmi_mode=1 hdmi_mode=87 hdmi_cvt 800 480 60 6 0 0 0   Once I launch a game it goes to a different resolution and my screen goes blank or corrupted.   How do I translate the above settings to the nes, snes, n64 GBA, GBC, GB, Genesis, Master System emulators etc?   Thank you for any help in this matter, I will attach a picture of my test setup for my recalbox portable im making.
      • tony-black
        My little 5 inch screen pic attached, it looks grainey but it has the plastic film still on for now till I get it inside a 3D printed case.
        • tony-black
          Overall pic so far
          • digitaLumberjack
            Hi, yep sorry try to edit the file /recalbox/scripts/runcommand.sh and add
            eval $@
            sleep 1
            exit 0
            at the top, to avoid changing mode 🙂 Like this one : https://gist.github.com/digitalLumberjack/23c019841d7636fde57b
            • tony-black
              Wow thank you very much! EVERYTHING works now! All I need to do is tear a 360 controller open and split it in half on each side of the screen and fit my 6 amp hour battery then win!
              • digitaLumberjack
                Cool 😉
                • tlanks
                  tlanks last edited by
                  hi, digitalLumberjack i can not open this link ,and i need this Urgently https://gist.github.com/digitalLumberjack/23c019841d7636fde57b can you give me another? or some mirror site ?,or give me a .doc  .pdf ..... thank you   my email:   tlanks@126.com                99096017@qq.com
                  • nin_mania
                    nin_mania last edited by
                    Hi, Here is the raw file i just download, i put it as .txt for easier reading 😄
                    • tlanks
                      hi there is Something wrong with KODI can you fix it ?
                      • alucardxs
                        alucardxs last edited by
                        Hi,   ho did you get the screen working ? I've got the icon of recalbox but the menu does not appear, I've got a screen with lines of white eand grey pixels ... Thanks
