    Solved Final Fantasy Tactics Advance Freez?
    fantasy tactics advance freez
    2479
    • Shadowxgp
      Shadowxgp last edited by
      Final Fantasy Tactics Advance after like around 30 seconds it freeze then i'm force to unpower the pi 3 and repower it again but any other GBA games works fine is there a fix for this?
      Pizza
        paradadf Staff @Shadowxgp last edited by
        @shadowxgp try using another core. Press select on the rom, edit metadata and modify the first two lines (look for possible combinations!)
        Shadowxgp 3 Replies Last reply Reply Quote 1
        • Shadowxgp
          Shadowxgp @paradadf last edited by
          @paradadf ok i'll try that
          Pizza
          • Shadowxgp
            @paradadf it still's freeze i only have 1 option on the Metadata on the Emulator libretro and default & on the Core only default ?
            Pizza
            • Shadowxgp
              oh wait i have more on the Core after selecting libretro
              Pizza
              • Shadowxgp
                @paradadf Thank you so Much keep up the Awesome work
                the game works on GPSP
                Emulator: libretro
                Core: GPSP
                Pizza
