    N64 games do not launch in 4.0.2
    Emulator Arcade/PC/Console
    launch 4.0.2
    • Aaron Paluzzi
      Aaron Paluzzi last edited by
      Hello,
      I'm having issues with Recalbox and N64 roms. Like a few people before me I'm seeing recalbox launch the game to a black screen only to return to recalbox directly. I've double checked my settings to rule out the screen resolution issue as well as the controller mapping issue. I've used ssh and checked that my television supports the needed modes, and I've set up my controller to map L1 and R1. I've also tried this on multiple systems with either PS3 controllers with a external Bluetooth adaptor, and wired Xbox 360 controllers.
      At this point I'm not sure what the issue is. I'm using the same roms I used on my systems previous incarnation as a retropie so I'm sure the roms work. I came over due to the ease of setup (retropie setups took days, this is mostly plug and play). So far only the n64 is an issue.
      What else can I try?
      paradadf Substring 2 Replies Last reply Reply Quote 0
        paradadf Staff @Aaron Paluzzi last edited by
        @aaron-paluzzi n64 roms must be unzipped!
          Substring @Aaron Paluzzi last edited by
          @aaron-paluzzi I hope you don't have a pi0 or pi1 ?
