    Solved SD sandisk 200Gb work verygood
    Your discoveries
    sandisk 200gb verygood
    3490
    • gothrek
      gothrek last edited by
      Hi guys,
      my experience with:
      https://www.amazon.it/dp/B00V62XBQQ/ref=twister_B072JZ23JP?_encoding=UTF8&psc=1
      was be very good.
      All works very well.
      my 2 cents
      • lackyluuk
        @gothrek Can you provide some details so I can update the Wiki
        • recalbox version:
        • Raspberry Pi Model:
        • Actual size of the card and how much space for games
        Anyway, I really recommend to use a external USB Stick and separate the OS from your data ๐Ÿ™‚
        gothrek 1 Reply Last reply Reply Quote 0
        • gothrek
          gothrek @lackyluuk last edited by gothrek
          @lackyluuk
          hi, yes sorry:
          recalbox version 4.0.2
          Raspeberry PI3
          Size completly free for roms 178Gb after install the o.s.
          lackyluuk 1 Reply Last reply Reply Quote 0
          • lackyluuk
            lackyluuk Translator @gothrek last edited by
            @gothrek thank you ๐Ÿ™‚
            • Cthulhus
              Cthulhus last edited by
              @gothrek said in SD sandisk 200Gb work verygood:
              Thanks ! I'll have a look. Space is exactly what I need now.
              C'รฉtait mieux avant :-)
              • Defiant
                Defiant last edited by
                I use the exact same one, works flawlessly!
                Copyright ยฉ 2021 recalbox.com
