    Start/Stop Button + GPIO 4-player Controls (Gamecon Driver)
    GamePad/GPIO/USB encoder
    startstop button gpio 4-player controls
    4861
    • BornDead
      BornDead last edited by
      Re: Start/Stop Button + GPIO Controls
      I´m building a Recalbox inside an old NES case with two original snes ports and two original nes ports and would like to be able to use the original power and reset buttons. I have already set up the controllers and now I would like to add the buttons.
      Would it be possible to use 4-player gamecon when using Start/Stop reset and led?
      There would be a conflict on pin03 and pin05
      Player 5 and reset pin on the same GPIO pin. Player 6 and power pin on the same GPIO pin.
      The two I´m talking about are these:
      https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
      https://github.com/recalbox/recalbox-os/wiki/Gamecon-controllers-(EN)
      alt text
        Substring @BornDead last edited by
        @borndead You can edit the power script and change pins
        BornDead 1 Reply Last reply Reply Quote 0
        • BornDead
          BornDead @Substring last edited by
          @substring
          Thank you that would be perfect. Where do I find the script file to edit?
          What pins could I change to?
            @borndead I din't know which pins would ve free once you configured what you need. The script sgould be in /recalbox/scripts
            BornDead 2 Replies Last reply Reply Quote 0
            • BornDead
              @substring said in Start/Stop Button + GPIO 4-player Controls (Gamecon Driver):
              I tried GPIO13 and GPIO19. Reset and power off is working, but power on is not working.
              • BornDead
                @substring
                I tried changing back rpi-pin356-power.py to original pins and rewired, then reset, power off and power on is working. Must be something special with pin5 (GPIO3).
                Do you know anything about changing the pins of player 5 and 6 on the Gamecon Driver?
                  @borndead That would require rewriting the driver itself
                  • BornDead
                    BornDead @Substring last edited by BornDead
                    @substring
                    That´s what I ended up doing, after a lot of trying I successfully got what I wanted by editing gamecon_gpio_rpi.c and rebuilding the driver.
                    So now I have 4 gamecon gpio controllers, POWER, RESET and LED!
                    • PIN01 | 5V
                    • PIN06 | GROUND
                    • PIN19 | CLOCK
                    • PIN23 | LATCH
                    • PIN07 | DATA3 (NES1)
                    • PIN26 | DATA4 (NES2)
                    • PIN29 | DATA5 (SNES1)
                    • PIN31 | DATA6 (SNES2)
                    alt text
                    The code replace in gamecon_gpio_rpi.c:
                    /* GPIO pins 0, 1, 4, 7, 29, 31 */
                    static const int gc_status_bit[] = { 0x01, 0x02, 0x10, 0x80, 0x20, 0x40 };
                    static const int gc_gpio_ids[] = { 0, 1, 4, 7, 29, 31 };
                    Felipe_e 1 Reply Last reply Reply Quote 0
                    • Felipe_e
                      Felipe_e @BornDead last edited by
                      @borndead
                      Sorry for reliving this issue, but I could not reach the solution you explain.
                      I have the same problem, I want to connect 4 controls (2 snes and 2 nes) and the power off and reset buttons.
                      The truth is that I don't know how to rebuild the driver.
                      In this link is version 1.4 of the driver, it is easier to modify the pins, but my problem is in reinstalling the driver
                      https://github.com/marqs85/gamecon_gpio_rpi/tree/master/gamecon_gpio_rpi-1.4
