    Simulate keypress (key 5) to insert coin at Mame
    GamePad/GPIO/USB encoder
    simulate keypress key insert coin
    • jeffprestes
      jeffprestes last edited by
      Hi,
      I am trying to develop a small software to simulate the key 5 of keyboard to virtually insert coin to MAME games. But there's no uinput interface at /dev/input of Recalbox Linux.
      How could I do this?
      I've tried several examples with Go, Python and C and they didn't work out.
      Thanks in advance,
      -Jeff
      voljega Substring 2 Replies Last reply Reply Quote 1
        voljega Banned @jeffprestes last edited by
        @jeffprestes you know you just have to press select on your controller to do that right ?
          Substring @jeffprestes last edited by
          @jeffprestes Hi,
          I guess it's rather linked to the fact we're autoconfiguring each emulators. In you case, you first need to create a uinput device, which is up to your code I'd say. But there should be pther ways, i think i've already had a successful try with python-evdev (but it's not on recalbox by default)
          jeffprestes 1 Reply Last reply Reply Quote 0
          • jeffprestes
            jeffprestes @Substring last edited by
            @substring Thanks!
            I am visiting this page: https://python-evdev.readthedocs.io/en/latest/install.html
            Which distro should I use? Which Linux distro Recalbox is based on ?
            If it works for Python, as I am Go Developer I will try to include input.h and create a default binary for Recalbox.
              @jeffprestes Recalbox is made with buildroot. That's some kind of LFS project aimed for embedded systems. That's why it's not using apt/rpm/whatever : recalbox doesn't sit on top of an existing OS, but is anwhole OS itself.
              Regarding go, it may be included.
              Why do you need to add a "software pad" ?
