    Solved Controls does not work on FDS
    Emulator Arcade/PC/Console
    controls does fds
    2726
    • Cotox
      Cotox last edited by
      Hi Guys,
      I just install some roms of FDS and the joypads are not working.
      I´ve tested XBOX 360 wired (both original and clone), ps3 original and usb snes .
      As example, trying to play Doki doki Panic, the control just does not work.
      Anyone with the same issue? could someone help me?
      Tks,
      Cotox
        Substring @Cotox last edited by
        @cotox without your recalbox version, we're all dommed ...
        • Cotox
          Sorry, The Recalbox version is 4.0.2.
          I´ve tried last week with other controllers, from PS4 and another generic from friends, same result in all...
            voljega Banned @Cotox last edited by
            @cotox just tried Electrician and Doki Doki Panic, both work fine for me.
            You know you must change d**k side for the game to start ? I can't remember wich button it is exactly but just tried them one after the other
            Cotox 1 Reply Last reply Reply Quote 0
            • Cotox
              Cotox @voljega last edited by Cotox
              @voljega let me try, I was not aware about this disk side procedure.
              • Cotox
                Solved. Just change disk side with "L" .
                Tks @voljega
                  @cotox enjoy fds 🙂
