    Retrolink USB N64 Controller
    GamePad/GPIO/USB encoder
    retrolink usb controllers n64 usb help
    • eagleeye1011
      eagleeye1011 last edited by
      Re: N64 Controller
      Hey guys! Im new to this forum. I was using Retropi for awhile and thought I would try Recalbox. I have to say it appears to be more user friendly but I am having a really difficult time figuring out how to get my new Retrolink USB N64 controller working with the N64 games I have loaded on my USB flash drive connected to my Raspberry Pi 3. Im usining Recalbox OS version 4.0.1. Do I have to use the method in the wiki article for Recalbox 3.3? I would like to use the button combination Z + Start to exit the game amd return to the menu and another button combination for save and load (suggestions?) How do I accomplish all of this?
      • abunille
        abunille @eagleeye1011 last edited by abunille
        @eagleeye1011
        Hi,
        is this the same Controller?
        Can it solve your problem?
        https://forum.recalbox.com/topic/3471/n64-controller-and-recalbox
        You are in the german corner. Next time please post in the english area 😉
        eagleeye1011 1 Reply Last reply Reply Quote 0
        • eagleeye1011
          eagleeye1011 @abunille last edited by
          @abunille
          Thanks for your help. Yes that is the controller I have.
          I'll take a look at the post later. From a glance that looks like exactly what I'm looking for. Thank you!
          • abunille
            @eagleeye1011
            i hope it works 😉
            If everything is good please mark as "solved"
