    N64 controller and recalbox.
    GamePad/GPIO/USB encoder
    4.0.0 generic n64 usb controller
    9
    23
    33517
    • Zelaf
      Zelaf last edited by
      Hello, I installed Recalbox yesterday and was amazed by it's features and that it came with Kodi inbuilt.
      So because I wanted to go all out on the gaming experience I bought an n64 controller. To my surprise it was hard to configure properly and get it to work since it doesn't have a select button or a good button to use as a hotkey.
      Is there any way to configure the n64 controller to be usable within EmulationStation and the other emulators aswell as mupen64?
      Thanks for any help đŸ™‚
      Here's some controller info if needed.
      It's name is Generic USB Controller and has a n64 controller layout. It's made by Retrolink.
      Here's an amazon page: https://www.amazon.com/Retrolink-Nintendo-64-Classic-Enabled-Controller/dp/B008L3UUPS
      Thanks again!
        Hey
        Know that the N64 controller is the weirdest ever, and no other pad looks like it. So it is a bit complicated to map "normal pad layout" for the N64.
        BUT : you can override that by :
        • reading https://github.com/recalbox/recalbox-os/wiki/Configure-N64-controllers-(EN)
        • the wiki was written for recalbox 3.3. The files you will need to edit are both stored in /recalbox/share/system/configs/mupen64
        • you need to add n64.configfile=dummy in recalbox.conf
        Zelaf eagleeye1011 fiveminutebreak 3 Replies Last reply Reply Quote 0
        • Zelaf
          Zelaf @Substring last edited by
          @subs Thank you so much for this! I can now play Starfox smoothly đŸ™‚
          When configuring the buttons in ES I decided to go with a bit of imagination.
          For the start and select I used the joystick right and left and then the start button as the hotkey, seemed to work really nicely! đŸ˜„ And then A and B on A and B and then C left and down for X and Y. For some reason the button swaps in Emulation Station... Any fix for this?
          • boxcarpilot
            boxcarpilot last edited by
            Because it falls into the topic title...
            I'm guessing that will the xbox 360 controller will be enough... right?
            I mean... I can map C buttons to the right stick(gamecube style)... and Z to be like RB (again gamecube style)... correct?
            I wonder... is there any way I can do this like... manually? Maybe editing the same n64configfile I guess....
              Substring @boxcarpilot last edited by
              @boxcarpilot you wot need to edit anything, all is mapped in a clever way đŸ™‚
              • Victor GuimarĂ£es Barreto Alves
                Victor GuimarĂ£es Barreto Alves last edited by
                hey guys....
                well, I have the same problem here... I've changed the recalbox.conf and InputAutoCfg.ini using notepad++, and it didn't work.
                does anyone knows what I might be doing in a wrong way?
                Or, is there any possibility to share those files with me? Thanks in advance !!!
                  Substring @Victor GuimarĂ£es Barreto Alves last edited by
                  @Victor-GuimarĂ£es-Barreto-Alves have you read the topic at least ? N64 is autoconfigured.
                  • eagleeye1011
                    eagleeye1011 @Substring last edited by
                    @Substring
                    Okay so I just recently installed Recalbox 4.0.1 on my Raspberry Pi 3 and purchased the same controller as @Zelaf. I'm having trouble configuring it to work. I logged into root access, used the js command, which listed the Retorlink controller as something to the effect of, "Joystick (Generic Joystick .....)" I then used the "nano /usr/share/mupen64plus/InputAutoCfg.ini" command to edit the InputAutoCfg.Ini file but noticed my controller name (Joystick (Generic Joystick....) in the list with the exact same button configuration as that in the Github forum. Do I need type a whole new configuration or can I simply edit the configuration that matches my controller to read "Retrolink N64 controller" or something to that effect? Also, how do I add n64.configfile=dummy in recalbox.conf? Thanks for the help. Really excited about playing old N64 games.
                      Substring @eagleeye1011 last edited by
                      @eagleeye1011 If it exists, just edit recalbox.conf to add the specified line. You can use nano ~/recalbox.conf to do so
                      eagleeye1011 2 Replies Last reply Reply Quote 0
                      • eagleeye1011
                        @substring Can you explain this further so I understand? Very new to this whole thing.
                          @eagleeye1011 I guess editing the recalbox.conf must be detailled in the wiki ...
                          The easy way if you're running windows : open yout browser to http://recalbox/
                          • eagleeye1011
                            eagleeye1011 @Substring last edited by eagleeye1011
                            @substring I've tried the "nano ~/recalbox.conf" command and it did nothing. I am more than likely very confused. What is the purpose of adding "n64.configfile=dummy" in recalbox.conf and how exactly do I do this step by step.
                              Substring @eagleeye1011 last edited by Substring
                              @eagleeye1011 said in N64 controller and recalbox.:
                              How and where did you try it ? Have you followed https://github.com/recalbox/recalbox-os/wiki/Root-access-on-terminal-(EN) ?
                              Have you tried the URL I gave you ?
                              The n64.configfile=dummy prevents recalbox from auto-configuring N64 depending on your pad setup. It's mandatory if you want to customize your inputs as they don't follow the main configuration rule.
                              • fiveminutebreak
                                fiveminutebreak @Substring last edited by
                                @substring Tried every method to access InputAutoCfg, and cannot find a way to access it with write permission. Every time it opens as read-only. Is there something I'm missing or something that changed?
                                  Hello
                                  https://github.com/recalbox/recalbox-os/wiki/Make-a-partition-writable-(EN)
                                    Substring @fiveminutebreak last edited by
                                    @fiveminutebreak That file is in /recalbox/share/system/configs/mupen64 which is writeable
                                    • dh04000
                                      dh04000 last edited by
                                      @Substring
                                      Hey, I recently purchased one of these controllers myself, and I can't seem to get it to work. I followed the (https://github.com/recalbox/recalbox-os/wiki/Configure-N64-controllers-(EN)) but jstest won't work. I added this (n64.configfile=dummy) to the end of my recalbox.conf file. I tried to manually edit the InputAutoCfg.ini file (nano /recalbox/share/system/configs/mupen64/InputAutoCfg.ini) and added the following to the end of the file:
                                      [Generic USB Joystick]
                                      plugged = True
                                      plugin = 2
                                      mouse = False
                                      AnalogDeadzone = 4096,4096
                                      AnalogPeak = 32768,32768
                                      DPad R = hat(0 Right)
                                      DPad L = hat(0 Left)
                                      DPad D = hat(0 Down)
                                      DPad U = hat(0 Up)
                                      Start = button(9)
                                      Z Trig = button(7)
                                      B Button = button(8)
                                      A Button = button(6)
                                      C Button R = button(1)
                                      C Button L = button(3)
                                      C Button D = button(2)
                                      C Button U = button(0)
                                      R Trig = button(5)
                                      L Trig = button(4)
                                      Mempak switch =
                                      Rumblepak switch =
                                      X Axis = axis(0-,0+)
                                      Y Axis = axis(3-,3+)
                                      But, I don't think it sees the changes I made when I start up the emulator. Just what changes I made in the controller config GUI in the controller menu.
                                      • dh04000
                                        @Substring
                                        Never mind. I found the problem, I had an extra bracket far right to the controller name.
                                        To help other's with this controller. here's my controller config:
                                        plugged = True
                                        plugin = 2
                                        mouse = False
                                        DPad U = hat(0 Up)
                                        Start = button(9)
                                        Z Trig = button(7)
                                        R Trig = button(5)
                                        L Trig =
                                        Mempak switch =
                                        Rumblepak switch =
                                        I unmapped the left trigger to use for the mupen64plus.cfg, where I mapped J0B4/B9 as exit emulation, J0B4/B6 as save state, and J0B4/B8 as Load state. These options are changed in the [Core Options].
                                        What is the command for Hat0 left or right though..... do you know Substring?
                                        Substring Chris Matthes 2 Replies Last reply Reply Quote 1
                                          Substring @dh04000 last edited by
                                          @dh04000 said in N64 controller and recalbox.:
                                          i don't understand
                                          dh04000 1 Reply Last reply Reply Quote 0
                                          • dh04000
                                            dh04000 @Substring last edited by
                                            @substring said in N64 controller and recalbox.:
                                            i don't understand
                                            I should have written more clearly. What I was asking is what the symbol for directon pads looks like in the mupen64plus.cfg file. Player 1 Button 9 is J0B9. What is Player 1 direction pad right? J0(something)?
