    Unsolved Amiga, Stand der Dinge?
    Emulatoren Arcade/PC/Konsole
    amiga stand der dinge
    11
    113
    64694
    • freaky69
      freaky69 @abunille last edited by
      @abunille Sorry for the missunderstanding... I meant BIOS Files for the AMIGA ;)... There Filename is .... .rom
      • Wulfman
        Wulfman last edited by
        Kickstart liegt dabei.
        freaky69 1 Reply Last reply Reply Quote 0
        • freaky69
          freaky69 @Wulfman last edited by
          @wulfman said in Amiga, Stand der Dinge?:
          Vielen Dank 🙂 Hab es von voljega auch erfahren 😉 Das File welches Du geupped hast ist das auch schon bei der 4.0.1 dabei?? Wenn ich diese Version update auf 4.1.0 bleibt diese aber vorhanden, oder??
            voljega Banned @freaky69 last edited by
            @freaky69 you'll just need another lib that @Wulfman updated a few posts back on this thread
            • bspinner
              bspinner last edited by bspinner
              Hey,
              just trying to get it up and running on a freshly setup Recalbox 4.1.
              I receive the following error:
              ./uae4arm: error while loading shared libraries: libbcm_host.so: cannot open shared object file: No such file or directory
              Any ideas?
              @voljega I just created a pull request to fix some errors in the readme. And maybe you should remove the kickstart files from the repository so Cloanto doesn't get mad at you.
              edit: Looks like the file several library files are missing in the Recalbox image for ODROID XU4.
              voljega 2 Replies Last reply Reply Quote 0
                voljega Banned @bspinner last edited by
                @bspinner ah yeah additional libs are maybe missing in the Odroid Case, this was done for Pi2 and Pi3
                  voljega Banned @bspinner last edited by voljega
                  @bspinner
                  for the missing libs, you can try the method I used when I had to find some missing ones for Pi2/3 : https://github.com/midwan/amiberry/issues/72
                  you'll need a raspbian on the side :s
                  EDIT : anyway the executable is compiled for Pi2/Pi3 and amiberry (I switched to amiberry, kept the name uae4arm) doesn't officially support OdroiD XU4 so I really doubt this will work on XU4
                  bspinner 1 Reply Last reply Reply Quote 0
                  • bspinner
                    bspinner @voljega last edited by bspinner
                    @voljega
                    OK, the obvious reason for missing libs is the different hardware. libbcm_host is for some broadcom chip the raspberry pi has.
                    • Ratte
                      Ratte last edited by Ratte
                      Hi, in diesem Thread habe ich bisher nichts geschrieben.
                      Die CD32 Emulation baut unter anderem auf voljega´s Arbeit auf. Ich kann nicht oft genug betonen, dass ich hier keine Konkurrenz schaffen möchte.
                      Ich habe mir vor einigen Monaten gedacht, dass die CD32 Console nur ein CD-Laufwerk hat und ohne Tastatur und Maus daher kommt. Also ideale Voraussetzungen für eine Emulation mittels Recalbox.
                      Es gibt über 150 CD32 Spiele, teilweise nur einfach angepasste A1200 Titel aber wenn es zusätzlich im Hintergrund noch etwas WAV/MP3 Sound gibt ist es ja kein Nachteil.
                      Dann gibt es da noch die Sache mit den WHD-Load Games und den ganzen A500/1200 Spielen ...
                      Die Amiga Community hat die letzten 25 Jahre nicht Däumchen gedreht, natürlich hat sich auch die CD32-Fangemeinde (innerhalb der Amiga-Szene) hingesetzt und hat fleißig Compilation-CDs mit WHD-Load Games gebaut.
                      Hunderte von Spielen wurde so über die Jahre getestet, Skripts wurden geändert und angepasst, für Unmengen an Spielen und nicht zu vergessen auch supergeile Szenedemos.
                      Ich schätze die Arbeit und die Unterstützung der anderen Amiga-Recalbox Entwickler, dass steht außer Frage.
                      In meinen Augen wäre es jedoch eine rundere Sache alles über das CD32 abzuwickeln, da gibt es die WHD-Load Spiele bereits Pfannenfertig.
                      Die Alternative mit der A500/1200 Emulation würde doch bedeuten, dass man die 25 Jahre Erfahrung aus der Amiga-Szene komplett neu durchleben müsste.
                      Jedes Game von Hand anpassen, etc. etc.
                      Und dann noch die Frage wie man dran kommen würde, jemand müsste diese neu gestrickten Packages auch hosten.
                      Die CD32-Images hingegen gibt es schon zig Jahre .. inkl. der WHD-CompilationCDs.
                      Ich glaube hier würde unnötig Manpower verbraucht werden.
                      Beim besten Willen, ich will keine Konkurrenz und keinen Ärger machen, aber ich glaube man hat sich so sehr in eine Sache verbissen (A500/1200), dass man nicht sehen will, dass es leichter (CD32) zu bewerkstelligen geht.
                      Mir fehlt die Erfahrung und das Hintergrundwissen zu Emustation und den Abhängigkeiten der einzelnen Skripte um die Emulation sauber im Recalbox-Style einzubinden, gerne würde ich das Projekt gemeinsam in dieser Richtung abschließen. Alleine werde ich dass nicht kurzfristig hinbekommen.
                      •Raspberry Pi model: Pi ZeroW
                      •Raspberry Pi model: Pi 3B @ 1350/500/500 MHz
                      •Raspberry Pi model: Pi 3B+ @ 1550/500/500 MHz
                        voljega Banned @Ratte last edited by
                        @ratte I already worked on official integration and CD32 will be there alongside A500/1200 (as soon as amiberry resolves mapping problems for it), so no need to worry about which of the amiga machine is simpler to use or not.
                        • Wulfman
                          Hallo zusammen,
                          vielleicht nicht ganz richtig hier - aber vielleicht kann hier jemand helfen oder hat eine Idee:
                          Ich hab mir heute einen "Amiga-Joystick" gebastelt - ich habe dafür den "DragonRise Inc. Generic USB Joystick"-Controller verbaut. Unter Windows wird der Sauber eingerichtet - Richtungen + Button 1, Button 2 werden passend erkannt. Auch das Einrichten unter ES klappt - Richtungen, Button 1, Button 2. Im Amiga-Emulator klappt es nicht ... Hier hab ich Button 1 (gerade kein 2-Button-Spiel zur hand) und links/rechts. Hoch/Runter fehlt. Ich hab in ES bei der Controller Config alle 3 Richtungseinstellmöglichkeiten probiert. In ES klappt hoch/runter dann auch ... aber Amiga 😞
                          Jemand eine Idee was ich mal probieren könnte?
                            voljega Banned @Wulfman last edited by
                            @wulfman did you try with another emulator to see if up and down where working ? Like snes ?
                            Wulfman 1 Reply Last reply Reply Quote 0
                            • Wulfman
                              Wulfman @voljega last edited by
                              @voljega said in Amiga, Stand der Dinge?:
                              SNES works
                                @wulfman did you try with only game and is it 600/1200 or CD32 ?
                                • Wulfman
                                  i've tried some 600/1200-Games. Like Lotus 3, James Pond, Dynablaster. Only Left/Right und Fire 😐
                                    @wulfman strange... no issue on my side.
                                    I think we'll have to wait for next amiberry version which will handle controller better :s
                                    • Wulfman
                                      Same Problem @ Amiberry https://github.com/midwan/amiberry/issues/114
                                      "Fixed with new control system :)" ... mhhh ... Your amiberry-version is oldern than this from October? Or is this something which i can do now?
                                        voljega Banned @Wulfman last edited by voljega
                                        @wulfman there is a 2.5 beta version you can try it (but you will be missing one icon file and something else I don't remember, which you'll have to get somewhere).
                                        Personnaly I'm waiting for 2.5 final to update my version
                                        • Wulfman
                                          Wulfman last edited by Wulfman
                                          2.5beta doesn't allow to join Config-Menu ... Back2ES 😐 ... ok i will wait for 2.5 final 😐
                                            @wulfman yeah or you can try with another controller
