    TERIOS T3 of Gearbest NOT works, anyone with this pad?
    GamePad/GPIO/USB encoder
    terios gearbest anyone pad
    13797
    • charlesmarried
      charlesmarried last edited by
      Hi, I recently bought this gamepad:
      alt text
      Wit this wireless reciever:
      alt text
      And I cant connect both of them to the recalbox. Its impossible to connect. Anyone has this gamepad for help?
      Thank you!
        Substring @charlesmarried last edited by
        @charlesmarried hi
        I hve pretty much the qame looking pad (ewcept buttons are labelled fornPS3) and it does work. Mine is a shanwan, a chinesendual shock 3 clone.
        You should make a support archive so that we can check
        charlesmarried 1 Reply Last reply Reply Quote 0
          https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN)
          • charlesmarried
            Sorry for the delay,
            I have to do the support archive with the USB dongle Connected i Guess and with the gamepad on?
            Thanks
            • charlesmarried
              charlesmarried @Substring last edited by charlesmarried
              @substring @rockaddicted
              Hi again and sorry for the delay. My controller is Shanwan too. Here is the support, it is done with the dongle connected and with the gamepad trying to find the dongle. Please some help, thank you!!!
              http://www34.zippyshare.com/v/kZZMp8bc/file.html
                and if you set this driver in your recalbox.conf file :
                controllers.ps3.enabled=1
                ## Choose an driver between official, shanwan and gasia if you have dualshock clones (official,shanwan,gasia)
                controllers.ps3.driver=shanwan
                official -> shanwan
                Then follow the pairing instructions ?
                https://github.com/recalbox/recalbox-os/wiki/Manual-(EN)#ps3controllers
                • charlesmarried
                  charlesmarried @rockaddicted last edited by
                  @rockaddicted
                  Hi, I have done what do you say and It does not work. Could be the dongle that id not supported by?
                    @charlesmarried
                    in archive support only gamepad or you connected wireless keyboard ?
                    I need archive support with only dongle and gamepad
                    edit : your gamepad sent keyboard events, it s bad
                    https://github.com/recalbox/recalbox-os/wiki/Make-a-partition-writable-(EN)
                    you need to edit /etc/udev/rules.d/99-joysticks-exotics.rules
                    add this line
                    #TERIOS GAMEPAD
                    SUBSYSTEM=="input", ATTRS{name}=="HID 4555:1031", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
                    SAVE AND REBOOT
                    Try to configure gamepad in Emulationstation Menu
                    if doesn't work, post a new archive support
                    • charlesmarried
                      charlesmarried @acris last edited by charlesmarried
                      @acris said in TERIOS T3 of Gearbest NOT works, anyone with this pad?:
                      #TERIOS GAMEPAD
                      All right, Im going to do it right now!
                      • charlesmarried
                        @acris @rockaddicted @Substring
                        Well I have done everything and it still not working. Recalbox says that there is another gamepad recognised but the gamepad cannot find the dongle. Even, Recabolx crash, I can´t use the keyboard as normal and I have to power off the raspberry to reset. Here I upload another new support:
                        http://www99.zippyshare.com/v/8SeXAReV/file.html
                        Is a problem of the dongle? The gamepad works great with PC and Andorid. So, the gamepad itseilf is ok, even the dongle in Steam is fully recognized.
                        Thank you so much... it is a nightmare to config this pad
                          @charlesmarried
                          recalbox doesn't work with gamepad reconized like keyboard
                          you bought a bad gamepad
                          @substring peut pas voir la derniere archive si tu peux checker et voir peut etre un usbhid pour le dongle
                            @charlesmarried your pad works as a keyboard, not as a joypad. It doesn't send any event corresponding to a joypad. I have no idea if you can configure the keypresses, but the only trick (using the xarcade2jstick driver) could not even work unless your pad is configured like the mame inputs (or can be configured in such way).
                            • charlesmarried
                              @substring
                              But your actual controller is a Shanwan, no? Like mine. Any other idea?
                                @charlesmarried the shell is almost exactly the same, but the software inside is totally different
                                • charlesmarried
                                  @substring
                                  Where do you see that? In the recalbox support? What a pity 😞
                                  • charlesmarried
                                    charlesmarried @charlesmarried last edited by
                                    I think I will give it up, I will shell it and buy other... Terrible.
                                      I don't find your gamepad on gearbest, the only one I found is a bluetooth gamepad without a dedicated dongle.
                                      http://www.gearbest.com/video-game/pp_197587.html
                                      • charlesmarried
                                        @rockaddicted
                                        This is the gamepad I bought, and the dongle is this:
                                        https://goo.gl/3LpQXr
                                        That is for S3, T3 and G3 gamepads. The dongle on PC is recognised as a PS3/PC gamepad:
                                        alt text
                                        • charlesmarried
                                          So guys, before assuming that i lost my money in this gamepad, is there any possible option o it is the end?
                                            Did you buy the dongle separately or was it delivered with the controller?
                                            But yes wrong gmaepad please check wiki for best compatibility
                                            101.4k
