    USB Splitter not working
    GamePad/GPIO/USB encoder
    usb splitter divider 4-port hub
    3194
    • Cheddar
      Cheddar last edited by Cheddar
      I bought a 1-to-4 usb splitter in hopes of extending it for my controllers to reach, but unfortunately it does not work on Rasp.
      This works on win7. Is there a particular compatibility info I should look for? Or is the usb splitter solution off the table?
      Thanks
        Substring @Cheddar last edited by
        @Cheddar Do you have a link to that splitter ?
        Cheddar 1 Reply Last reply Reply Quote 1
        • kryptalivian
          kryptalivian last edited by
          I've had some of those before. I've found they're horrible quality and work when they want too. 😕
            Linux Kenal2.4 orlater ... That's not even some proper google translation lol
            You should check logs to make sure it's correctly detected by the OS.
            Cheddar 1 Reply Last reply Reply Quote 0
            • Cheddar
              Cheddar @Substring last edited by
              @Substring http://produto.mercadolivre.com.br/MLB-742999324-carregador-adaptador-usb-4-portas-hub-extensor-ampliador-usb-_JM it's this one. Just another "hey no brand but trust this is good"
              • Cheddar
                Cheddar @Substring last edited by Cheddar
                @Substring said in USB Splitter not working:
                I'm not sure I know how to lol
                *i just tested this on my PC and even though it says "charger" on the link, i connected keyboard and mouse to it and it worked perfectly
                  @Cheddar you can't compare with windows ...
                  Could be a current putput problem, try increasing it to 1A
                  • Cheddar
                    You're right, sorry..
                    I did what you suggested, now 1 of the 4 usb exits is working but the other 3 remain dead
