    Solved Audio PiZero
    audio pizero
    • jthemad
      jthemad last edited by
      Re: Raspberry pi zero audio output pwm not work
      Hi! I have the same exact problem.. GPIO controller and need GPIO audio.. where is the file config.txt for addìng pwm settings? Could you please show me all the strings I have to edit?
      Thanks all for the help
      Ps hardware is ok, I need only to set the pwm(mono)
      • ian57
        ian57 Staff last edited by
        @jthemad check this https://github.com/recalbox/recalbox-os/wiki/Analog-Audio-Pi-Zero-(EN)
        jthemad 1 Reply Last reply Reply Quote 0
        • jthemad
          jthemad @ian57 last edited by
          @ian57 thank you! Already tried it but it doesn't work.. Mono or stereo both don't work.. can anyone post all the strings to modify config.txt? Thank you
          • jthemad
            Ok problem solved.. must set Audio:JACK in audio menu.. now it works like a charm.. GPIO controller and pwm audio (mono).. thanks for the answer.. hi all
