    The Encoder Questions in TIM1 of STM32F407
    GamePad/GPIO/USB encoder
    encoder tim1 stm32f407
    • iran
      iran last edited by
      Hello~
      Please look at the following codes:
      [code]//TIM8,PC6 PC7
      RCC->APB2ENR |= 1<<1; //TIM8 timer enable
      RCC->AHB1ENR |= 1<<2; //GPIO port clock enable
      GPIOC->MODER &= 0xFFFF0FFF; //PC6,PC7 set to be reuse pattern
      GPIOC->MODER |= 0x0000A000;
      GPIOC->AFR[0] &= 0x00FFFFFF;
      GPIOC->AFR[0] |= 0x33000000;
      TIM8->ARR = 0xFFFF;
      TIM8->PSC = 0;
      TIM8->CCMR1 &= 0xFCFC;  //CC1 pass set to be input, IC1 map on TI1 ,CC2  pass set to be input, IC2 map on TI2
      TIM8->CCMR1 |= 0x0101;
      TIM8->CCER  &= 0xFFDD;
      TIM8->CCMR1 &= 0x0F0F;   //no flagging
      TIM8->SMCR  &= 0xFFF8;
      TIM8->SMCR  |= 0x0003;
      TIM8->CR1 |= 1<<0;     //enable counter
      //TIM1,PA8 PA9
      RCC->APB2ENR |= 1<<0; //TIM1 time enable
      RCC->AHB1ENR |= 1<<0; //GPIOAport clock enable
      GPIOA->MODER &= 0xFFF0FFFF;      //PA8,PA9 set to be reuse pattern
      GPIOA->MODER |= 0x000A0000;
      GPIOA->AFR[1] &= 0xFFFFFF00;
      GPIOA->AFR[1] |= 0x00000011;
      TIM1->ARR = 0xFFFF;
      TIM1->PSC = 0;
      TIM1->CCMR1 &= 0xFCFC;  //CC1 pass set to be input, IC1 map on TI1 上,CC2 pass set to be input, IC2 map on  TI2 上
      TIM1->CCMR1 |= 0x0101;
      TIM1->CCER  &= 0xFFDD;
      TIM1->CCMR1 &= 0x0F0F;   //no flagging
      TIM1->SMCR  &= 0xFFF8;
      TIM1->SMCR  |= 0x0003;
      TIM1->CR1 |= 1<<0; //enable counter[/code]
      As the codes we can see,TIM8 can counte as normal but TIM1 has no ** count and the DIR changes from up to now. I don’t know if is the USART1_TX of PA9 wrong? Or the reason occurred by hardware--STM32F407 ? Well, this is the datasheet of STM32F407: [http://www.kynix.com/uploadfiles/pdf8798/STM32F407VET6.pdf](link url) ,you can see more details about the hardware.
      Please help! Thanks.
      Best wishes~
        Substring @iran last edited by
        @iran Hi !
        how is that recalbox-related ? lol
        101.4k
