    Recalbox RGB/Scart Output kein Bild
    Recalbox
    recalbox rgbscart output kein bild
    25390
    • ian57
      ian57 Staff @Pietze last edited by ian57
      @Pietze Are you using the 4.1 release? I omitted to say , that it is working with the 4.1 release 😉
      see here for DL https://archive.recalbox.com/updates/v1.0/unstable/0_1498496360429_DSC_2389.jpg
      Pietze 1 Reply Last reply Reply Quote 1
      • Pietze
        Pietze @ian57 last edited by
        @ian57 Oh, well I should try 4.1! It's still 4.0.2 ^^
        However, that Pi2Scart is worth the trouble:
        alt text
        alt text
        • ian57
          ian57 Staff last edited by
          @Pietze I made my tests on 4.1. I think you should try the 4.1 release... and yes it gives some great images ... with some work to configure it . See http://strike-devices.net/index.php/pi2scart/ to reproduce the emulator config in recalbox for a better image.
          100.8k
