    What will happen with Xbox 360 when 4.1 goes stable?
    GamePad/GPIO/USB encoder
    happen xbox 360 4.1 goes
    2683
    • eb2016
      eb2016 last edited by
      Hi. I'm just wondering what will be happening with xbox 360 controllers when 4.1 goes stable? Will they just work automatically? or will there be changes to the drivers and we'll need to update the file (cant remember the file name) to make them work.
      I'm asking as I've built a couple of recal box units for friends that use these controllers and I'm worried that if they update their recalbox version when 4.1 goes live, that their controllers will stop working.
      Thanks
        Hello
        you need to remap gamepad.
        eb2016 1 Reply Last reply Reply Quote 0
        • eb2016
          eb2016 @acris last edited by
          @acris So you just mean remapping from the options menu in Recalbox?
          Will I need to change any config files?
            Substring @eb2016 last edited by
            @eb2016 the update process will manage the config, users won't have anything to do
              @eb2016 yes just remap in emulationstation menu your gamepad.
              • eb2016
                That's great news. I was worried I was going to have to get my friends to send me back their Recalbox units to fix.
