    Solved [4.1] edit boot.txt? Tutorial does not work anymore
    Recalbox general
    [4.1] edit boot.txt tutorial does
    • MarcDK
      MarcDK last edited by
      Hi!
      I wanted to edit my boot.txt but your tutorial does not work anymore: https://github.com/recalbox/recalbox-os/wiki/Edit-the-config.txt-file-(EN)
      mount -o remount, rw /boot
      mount: You must specify a filesystem type with -t.
      https://marc.tv
      • ian57
        ian57 Staff last edited by
        @MarcDK Nop :
        # mount -o remount, rw /boot
        # mount
        /dev/root on / type ext4 (rw,relatime,errors=remount-ro,data=ordered)
        devtmpfs on /dev type devtmpfs (rw,relatime,size=242384k,nr_inodes=60596,mode=755)
        proc on /proc type proc (rw,relatime)
        devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620,ptmxmode=000)
        tmpfs on /dev/shm type tmpfs (rw,relatime,mode=777)
        tmpfs on /tmp type tmpfs (rw,relatime)
        tmpfs on /var type tmpfs (rw,relatime)
        tmpfs on /run type tmpfs (rw,relatime)
        sysfs on /sys type sysfs (rw,relatime)
        /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocha**et=ascii,shortname=mixed,errors=remount-ro)
        /dev/mmcblk0p3 on /recalbox/share type ext4 (rw,noatime,data=ordered)
        • MarcDK
          Sorry, my bad. I ignored the "REMOTE HOST IDENTIFICATION HAS CHANGED!" message on my mac.
          https://marc.tv
          Substring 1 Reply Last reply Reply Quote 1
            Substring @MarcDK last edited by
            @MarcDK looks like you tried to connect to a newly formatted SD but your pi didn't change its IP address.
            MarcDK 1 Reply Last reply Reply Quote 0
            • MarcDK
              MarcDK @Substring last edited by
              @Substring Yes, that was the case. Sorry for the dump post.
              https://marc.tv
