    Need help with PS3 clone please
    GamePad/GPIO/USB encoder
    joystick bluetooth ps3 clone
    3699
    • Francisco Javier Villagra Garcia
      Francisco Javier Villagra Garcia last edited by
      Hi, I bought a PS3 clone joystick.
      Brand Name: RV77
      Model: CECHZC2U
      and a bluetooth dongle Cambridge radio.
      I tried to connect with the drivers official, shanwan and gasia, with no results
      The recalbox version is 4.0.2.
      I dont know what to do! please help
        paradadf Staff last edited by
        How did you try to connect the controller?
        Ps3 controllers need to be paired connecting them about 10 seconds over USB and then press the PS Button, not over the EmulationStation Menu like others.
        Francisco Javier Villagra Garcia 1 Reply Last reply Reply Quote 0
          Francisco Javier Villagra Garcia @paradadf last edited by
          @paradadf I connect the USB from 10 seconds or more and disconnect the controller and press the PS button.
            You could connect your controller to the usb (and preferably disconnect anything else from the ports) and execute the dmesg command to find out what kind of clone you have and use that driver.
            Another option (but finding that info is always useful) is upgrading to the 4.1 unstable as the bluetooth connection has been improved and new drivers or services are used that might be (more) compatible with your pad.
              @paradadf
              dmesg
              [ 0.000000] Booting Linux on physical CPU 0x0
              [ 0.000000] Initializing cgroup subsys cpuset
              [ 0.000000] Initializing cgroup subsys cpuacct
              [ 0.000000] Linux version 4.1.19-v7 (root@c4bc7cb1932e) (gcc version 4.9.3 (Buildroot 2016.02-git-dirty) ) #1 SMP Mon Feb 20 15:51:48 UTC 2017
              [ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
              [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
              [ 0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
              [ 0.000000] cma: Reserved 8 MiB at 0x1e400000
              [ 0.000000] Memory policy: Data cache writealloc
              [ 0.000000] On node 0 totalpages: 126976
              [ 0.000000] free_area_init_node: node 0, pgdat 80880fc0, node_mem_map 9dfa4000
              [ 0.000000] Normal zone: 1116 pages used for memmap
              [ 0.000000] Normal zone: 0 pages reserved
              [ 0.000000] Normal zone: 126976 pages, LIFO batch:31
              [ 0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
              [ 0.000000] [bcm2709_smp_init_cpus] ncores=4
              [ 0.000000] PERCPU: Embedded 12 pages/cpu @9efb1000 s20416 r8192 d20544 u49152
              [ 0.000000] pcpu-alloc: s20416 r8192 d20544 u49152 alloc=12*4096
              [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
              [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 125860
              [ 0.000000] Kernel command line: 8250.nr_uarts=0 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2709.boardrev=0xa22082 bcm2709.serial=0x6e382c05 smsc95xx.macaddr=B8:27:EB:38:2C:05 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.fiq_fix_enable=1 sdhci-bcm2708.sync_after_dma=0 dwc_otg.lpm_enable=0 console=tty3 loglevel=3 elevator=deadline vt.global_cursor_default=0 logo.nologo root=/dev/mmcblk0p7 rootwait fastboot noswap ro
              [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
              [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
              [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
              [ 0.000000] Memory: 485052K/507904K available (6064K kernel code, 534K rwdata, 1664K rodata, 444K init, 757K bss, 14660K reserved, 8192K cma-reserved)
              [ 0.000000] Virtual kernel memory layout:
              [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
              [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
              [ 0.000000] vmalloc : 0x9f800000 - 0xff000000 (1528 MB)
              [ 0.000000] lowmem : 0x80000000 - 0x9f000000 ( 496 MB)
              [ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
              [ 0.000000] .text : 0x80008000 - 0x807945dc (7730 kB)
              [ 0.000000] .init : 0x80795000 - 0x80804000 ( 444 kB)
              [ 0.000000] .data : 0x80804000 - 0x80889b10 ( 535 kB)
              [ 0.000000] .bss : 0x8088c000 - 0x809497dc ( 758 kB)
              [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
              [ 0.000000] Hierarchical RCU implementation.
              [ 0.000000] Additional per-CPU info printed with stalls.
              [ 0.000000] NR_IRQS:608
              [ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
              [ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
              [ 0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
              [ 0.000025] Switching to timer-based delay loop, resolution 52ns
              [ 0.000240] Console: colour dummy device 80x30
              [ 0.000435] console [tty3] enabled
              [ 0.000464] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
              [ 0.000484] pid_max: default: 32768 minimum: 301
              [ 0.000783] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
              [ 0.000797] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
              [ 0.001748] Initializing cgroup subsys blkio
              [ 0.001773] Initializing cgroup subsys memory
              [ 0.001796] Initializing cgroup subsys devices
              [ 0.001816] Initializing cgroup subsys freezer
              [ 0.001841] Initializing cgroup subsys net_cls
              [ 0.001890] CPU: Testing write buffer coherency: ok
              [ 0.001950] ftrace: allocating 20313 entries in 60 pages
              [ 0.048368] CPU0: update cpu_capacity 1024
              [ 0.048400] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
              [ 0.048412] [bcm2709_smp_prepare_cpus] enter
              [ 0.048544] Setting up static identity map for 0x8240 - 0x8274
              [ 0.050288] [bcm2709_boot_secondary] cpu:1 started (0) 17
              [ 0.050477] [bcm2709_secondary_init] enter cpu:1
              [ 0.050519] CPU1: update cpu_capacity 1024
              [ 0.050526] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
              [ 0.050912] [bcm2709_boot_secondary] cpu:2 started (0) 17
              [ 0.051076] [bcm2709_secondary_init] enter cpu:2
              [ 0.051098] CPU2: update cpu_capacity 1024
              [ 0.051104] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
              [ 0.051466] [bcm2709_boot_secondary] cpu:3 started (0) 17
              [ 0.051597] [bcm2709_secondary_init] enter cpu:3
              [ 0.051618] CPU3: update cpu_capacity 1024
              [ 0.051624] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
              [ 0.051687] Brought up 4 CPUs
              [ 0.051710] SMP: Total of 4 processors activated (153.60 BogoMIPS).
              [ 0.051719] CPU: All CPU(s) started in HYP mode.
              [ 0.051726] CPU: Virtualization extensions available.
              [ 0.052402] devtmpfs: initialized
              [ 0.071254] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
              [ 0.071485] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
              [ 0.072296] pinctrl core: initialized pinctrl subsystem
              [ 0.072826] NET: Registered protocol family 16
              [ 0.078083] DMA: preallocated 4096 KiB pool for atomic coherent allocations
              [ 0.079191] bcm2709.uart_clock = 48000000
              [ 0.083105] bcm2709: Mini UART enabled
              [ 0.083600] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
              [ 0.083612] hw-breakpoint: maximum watchpoint size is 8 bytes.
              [ 0.083761] Serial: AMBA PL011 UART driver
              [ 0.083812] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
              [ 0.083970] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
              [ 0.149111] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
              [ 0.149143] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
              [ 0.149696] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
              [ 0.149709] bcm2708-dmaengine 3f007000.dma: dma_debug:0
              [ 0.150281] SCSI subsystem initialized
              [ 0.150464] usbcore: registered new interface driver usbfs
              [ 0.150550] usbcore: registered new interface driver hub
              [ 0.150648] usbcore: registered new device driver usb
              [ 0.151185] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-11-25 16:03
              [ 0.178402] Switched to clocksource arch_sys_counter
              [ 0.219532] FS-Cache: Loaded
              [ 0.219786] CacheFiles: Loaded
              [ 0.229102] NET: Registered protocol family 2
              [ 0.230047] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
              [ 0.230115] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
              [ 0.230215] TCP: Hash tables configured (established 4096 bind 4096)
              [ 0.230279] UDP hash table entries: 256 (order: 1, 8192 bytes)
              [ 0.230309] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
              [ 0.230589] NET: Registered protocol family 1
              [ 0.230892] RPC: Registered named UNIX socket transport module.
              [ 0.230902] RPC: Registered udp transport module.
              [ 0.230911] RPC: Registered tcp transport module.
              [ 0.230919] RPC: Registered tcp NFSv4.1 backchannel transport module.
              [ 0.231988] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
              [ 0.233040] futex hash table entries: 1024 (order: 4, 65536 bytes)
              [ 0.246408] VFS: Disk quotas dquot_6.6.0
              [ 0.246722] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
              [ 0.248788] FS-Cache: Netfs 'nfs' registered for caching
              [ 0.249697] NFS: Registering the id_resolver key type
              [ 0.249739] Key type id_resolver registered
              [ 0.249749] Key type id_legacy registered
              [ 0.251777] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
              [ 0.251914] io scheduler noop registered
              [ 0.251934] io scheduler deadline registered (default)
              [ 0.252215] io scheduler cfq registered
              [ 0.254452] BCM2708FB: allocated DMA memory de800000
              [ 0.254477] BCM2708FB: allocated DMA channel 0 @ f3007000
              [ 0.259866] Console: switching to colour frame buffer device 80x30
              [ 0.263055] Serial: 8250/16550 driver, 0 ports, IRQ sharing disabled
              [ 0.264130] of_serial: probe of 3f215040.uart failed with error -28
              [ 0.264797] vc-cma: Videocore CMA driver
              [ 0.264808] vc-cma: vc_cma_base = 0x00000000
              [ 0.264817] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
              [ 0.264826] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
              [ 0.264987] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
              [ 0.276452] brd: module loaded
              [ 0.283529] loop: module loaded
              [ 0.284328] vchiq: vchiq_init_state: slot_zero = 0x9e880000, is_master = 0
              [ 0.285772] Loading iSCSI transport class v2.0-870.
              [ 0.286417] usbcore: registered new interface driver smsc95xx
              [ 0.286465] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
              [ 0.486732] Core Release: 2.80a
              [ 0.486745] Setting default values for core params
              [ 0.486778] Finished setting default values for core params
              [ 0.687120] Using Buffer DMA mode
              [ 0.687130] Periodic Transfer Interrupt Enhancement - disabled
              [ 0.687138] Multiprocessor Interrupt Enhancement - disabled
              [ 0.687147] OTG VER PARAM: 0, OTG VER FLAG: 0
              [ 0.687161] Dedicated Tx FIFOs mode
              [ 0.687421] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0x9e814000 dma = 0xde814000 len=9024
              [ 0.687449] FIQ FSM acceleration enabled for :
              [ 0.687449] Non-periodic Split Transactions
              [ 0.687449] Periodic Split Transactions
              [ 0.687449] High-Speed Isochronous Endpoints
              [ 0.687469] dwc_otg: Microframe scheduler enabled
              [ 0.687513] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80417640
              [ 0.687527] WARN::hcd_init_fiq:413: FIQ ASM at 0x804179b0 length 36
              [ 0.687541] WARN::hcd_init_fiq:438: MPHI regs_base at 0x9f89c000
              [ 0.687575] dwc_otg 3f980000.usb: DWC OTG Controller
              [ 0.687610] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
              [ 0.687642] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
              [ 0.687693] Init: Port Power? op_state=1
              [ 0.687701] Init: Power Port (0)
              [ 0.687889] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
              [ 0.687904] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
              [ 0.687917] usb usb1: Product: DWC OTG Controller
              [ 0.687929] usb usb1: Manufacturer: Linux 4.1.19-v7 dwc_otg_hcd
              [ 0.687941] usb usb1: SerialNumber: 3f980000.usb
              [ 0.688614] hub 1-0:1.0: USB hub found
              [ 0.688657] hub 1-0:1.0: 1 port detected
              [ 0.689033] dwc_otg: FIQ enabled
              [ 0.689042] dwc_otg: NAK holdoff enabled
              [ 0.689050] dwc_otg: FIQ split-transaction FSM enabled
              [ 0.689081] Module dwc_common_port init
              [ 0.689345] usbcore: registered new interface driver usb-storage
              [ 0.689541] mousedev: PS/2 mouse device common for all mice
              [ 0.690199] bcm2835-cpufreq: min=600000 max=1200000
              [ 0.691829] sdhci: Secure Digital Host Controller Interface driver
              [ 0.691834] sdhci: Copyright(c) Pierre Ossman
              [ 0.691976] sdhost: log_buf @ 9e813000 (de813000)
              [ 0.768410] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
              [ 0.790523] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
              [ 0.790531] mmc-bcm2835 3f300000.mmc: DMA channel allocated
              [ 0.825033] mmc0: host does not support reading read-only switch, assuming write-enable
              [ 0.826774] mmc0: new high speed SDHC card at address 0001
              [ 0.827004] mmcblk0: mmc0:0001 00000 29.8 GiB
              [ 0.828465] sdhci-pltfm: SDHCI platform and OF driver helper
              [ 0.828656] ledtrig-cpu: registered to indicate activity on CPUs
              [ 0.828728] hidraw: raw HID events driver (C) Jiri Kosina
              [ 0.828834] usbcore: registered new interface driver usbhid
              [ 0.828839] usbhid: USB HID core driver
              [ 0.829053] Initializing XFRM netlink socket
              [ 0.829069] NET: Registered protocol family 17
              [ 0.829137] Key type dns_resolver registered
              [ 0.829438] Registering SWP/SWPB emulation handler
              [ 0.829777] registered taskstats version 1
              [ 0.829874] vc-sm: Videocore shared memory driver
              [ 0.829882] [vc_sm_connected_init]: start
              [ 0.830193] [vc_sm_connected_init]: end - returning 0
              [ 0.832571] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
              [ 0.832713] mmcblk0: p1 p2 < p5 p6 p7 p8 >
              [ 0.835094] EXT4-fs (mmcblk0p7): couldn't mount as ext3 due to feature incompatibilities
              [ 0.838463] EXT4-fs (mmcblk0p7): couldn't mount as ext2 due to feature incompatibilities
              [ 0.847586] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
              [ 0.847608] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
              [ 0.851316] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
              [ 0.852825] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
              [ 0.854332] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
              [ 0.854624] devtmpfs: mounted
              [ 0.854980] Freeing unused kernel memory: 444K (80795000 - 80804000)
              [ 0.857042] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
              [ 0.888465] Indeed it is in host mode hprt0 = 00021501
              [ 0.943837] mmc1: new high speed SDIO card at address 0001
              [ 1.068420] usb 1-1: new high-speed USB device number 2 using dwc_otg
              [ 1.068509] Indeed it is in host mode hprt0 = 00001101
              [ 1.243832] udevd[99]: starting version 3.1.5
              [ 1.267487] random: udevd urandom read with 42 bits of entropy available
              [ 1.268632] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
              [ 1.268643] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
              [ 1.269074] hub 1-1:1.0: USB hub found
              [ 1.269140] hub 1-1:1.0: 5 ports detected
              [ 1.502258] cfg80211: Calling CRDA to update world regulatory domain
              [ 1.528722] brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO Drive strength init done for chip 43430 rev 1 pmurev 24
              [ 1.529345] usbcore: registered new interface driver brcmfmac
              [ 1.548688] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
              [ 1.648738] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
              [ 1.648755] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
              [ 1.650367] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
              [ 1.651570] smsc95xx v1.0.4
              [ 1.669362] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
              [ 1.722119] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:38:2c:05
              [ 1.798451] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
              [ 1.878411] usb 1-1.3: device descriptor read/64, error -32
              [ 2.068403] usb 1-1.3: device descriptor read/64, error -32
              [ 2.267951] bcm2835-rng 3f104000.rng: hwrng registered
              [ 2.268184] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
              [ 2.468445] usb 1-1.3: new full-speed USB device number 6 using dwc_otg
              [ 2.548445] usb 1-1.3: device descriptor read/64, error -32
              [ 2.612133] EXT4-fs (mmcblk0p8): couldn't mount as ext3 due to feature incompatibilities
              [ 2.612516] EXT4-fs (mmcblk0p8): couldn't mount as ext2 due to feature incompatibilities
              [ 2.738416] usb 1-1.3: device descriptor read/64, error -32
              [ 2.744965] EXT4-fs (mmcblk0p8): recovery complete
              [ 2.746823] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
              [ 2.928456] usb 1-1.3: new full-speed USB device number 7 using dwc_otg
              [ 3.008432] usb 1-1.3: device descriptor read/64, error -32
              [ 3.198464] usb 1-1.3: device descriptor read/64, error -32
              [ 3.388503] usb 1-1.3: new full-speed USB device number 8 using dwc_otg
              [ 3.808466] usb 1-1.3: device not accepting address 8, error -32
              [ 3.888467] usb 1-1.3: new full-speed USB device number 9 using dwc_otg
              [ 4.308426] usb 1-1.3: device not accepting address 9, error -32
              [ 4.308522] usb 1-1-port3: unable to enumerate USB device
              [ 4.508563] Bluetooth: Core ver 2.20
              [ 4.508617] NET: Registered protocol family 31
              [ 4.508622] Bluetooth: HCI device and connection manager initialized
              [ 4.508959] Bluetooth: HCI socket layer initialized
              [ 4.508969] Bluetooth: L2CAP socket layer initialized
              [ 4.509003] Bluetooth: SCO socket layer initialized
              [ 4.593615] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
              [ 4.593627] Bluetooth: BNEP filters: protocol multicast
              [ 4.593640] Bluetooth: BNEP socket layer initialized
              [ 4.658430] cfg80211: Calling CRDA to update world regulatory domain
              [ 5.724350] random: nonblocking pool is initialized
              [ 7.818423] cfg80211: Calling CRDA to update world regulatory domain
              [ 8.719603] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
              [ 10.978438] cfg80211: Calling CRDA to update world regulatory domain
              [ 14.138432] cfg80211: Calling CRDA to update world regulatory domain
              [ 17.298441] cfg80211: Calling CRDA to update world regulatory domain
              [ 18.364527] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
              [ 18.364542] brcmfmac: brcmf_add_if: ignore IF event
              [ 18.368469] brcmfmac: power management disabled
              [ 20.458425] cfg80211: Calling CRDA to update world regulatory domain
              [ 22.662108] NET: Registered protocol family 10
              [ 22.664588] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
              [ 23.618463] cfg80211: Calling CRDA to update world regulatory domain
              [ 26.778433] cfg80211: Calling CRDA to update world regulatory domain
              [ 29.938433] cfg80211: Calling CRDA to update world regulatory domain
              [ 33.098434] cfg80211: Calling CRDA to update world regulatory domain
              [ 36.258427] cfg80211: Exceeded CRDA call max attempts. Not calling CRDA
                I use other USB cable and when I connect to the RP the joystick begins to vibrate.
                When I use dmesg with the new cable its says SHANWAN.
                  paradadf Staff @Francisco Javier Villagra Garcia last edited by
                  @Francisco-Javier-Villagra-Garcia ok, good news because the output from above doesn't tell me anything.
                  Change recalbox.conf to use driver for shanwan clones and, VERY IMPORTANT, use a good cable for the pairing process.
                    Francisco Javier Villagra Garcia last edited by Francisco Javier Villagra Garcia
                    can I use more than 1 wireless controller? I can pair only one
                    I use recalbox 4.1 now and im using
                      Yes, you can. Two ps3 clones of the same type should work. A mix of different clones (shanwan, gasia) might not work (for everyone).
