    Unsolved Script to turn off cooler
    script turn cooler
    7
    24
    10426
    • azvarel
      azvarel @Pdagarcia last edited by
      @Pdagarcia where would you put this script?
      Zodian Theme | #SNESProject
      • lackyluuk
        lackyluuk Translator last edited by lackyluuk
        @azvarel I would place the script into /recalbox/scripts and call the script as a background process from the startup directory /etc/init.d for example as S32StartFanControl
        This could look like this (just one proposal, you can do it however you like it):
        #!/usr/bin/python
        import subprocess
        try:
            subprocess.Popen(["python","/recalbox/scripts/fanControl.py"])
        except KeyboardInterrupt:
            print "Quit"
        I have called my script that I start as fanControl.py
        azvarel 1 Reply Last reply Reply Quote 0
        • azvarel
          azvarel @lackyluuk last edited by
          @lackyluuk thanks 😃
          • marcelogarbin
            marcelogarbin last edited by
            @azvarel I'm with the same problem, did you work? which method did you use?
            100.2k
