    Moonlight won't launch games
    Emulator Arcade/PC/Console
    moonlight wont launch
    13271
    • DJAndrom3da
      DJAndrom3da @DJAndrom3da last edited by
      @DJAndrom3da said in Moonlight won't launch games:
      @Substring Alright I downgraded GFE to 3.0.5.22 but now when I try to pair it with recalbox it hangs on "Searching for server"
      Never mind I got it to detect my PC but I still can't launch games. Any other suggestions?
      • DJAndrom3da
        @Substring Downgrading didn't work, now what?
        • godhunter74
          godhunter74 last edited by
          Hi you can try to follow this :
          https://forum.recalbox.com/topic/3744/moonlight-not-pairing/12
          Relier un écran I2C et afficher des informations sur les roms
          DJAndrom3da 1 Reply Last reply Reply Quote 0
            Substring @DJAndrom3da last edited by Substring
            @DJAndrom3da reboot, it may happen that GFE takes some time to answer. And don't forget to login in GFE
            • DJAndrom3da
              DJAndrom3da @godhunter74 last edited by
              @godhunter74 Thank you but I already tried that
              • DJAndrom3da
                DJAndrom3da @Substring last edited by
                @Substring Still nothing
                  @DJAndrom3da ok now :
                  • connect via SSH
                  • run /etc/init.d/S31emulationstation restart
                  • keep ssh open and run a moonlight game. The error should be on the screen (avoid all the lvl0 messages from ES)
                  • DJAndrom3da
                    DJAndrom3da @Substring last edited by DJAndrom3da
                    @Substring http://imgur.com/2I5vPBF
                    Substring DJAndrom3da 2 Replies Last reply Reply Quote 0
                      @DJAndrom3da no configgen error, so it's a problem with moonlight
                      If you're familiar with unix, once you launched a moonlight game, check ~/.emulationstation/es_log.txt and find the python line launching emulatorlauncher.py and run it from command line. You should get the moonlight error (I hope).
                      If not, this method may be easier : there is a line that should look like ['/usr/bin/moonlight', '-input', '/dev/inputX', '-mapping', ...... ,'game.moonlight']. Just make a normal command line from it and launch it and report output please.
                      • DJAndrom3da
                        DJAndrom3da @DJAndrom3da last edited by DJAndrom3da
                        @Substring Sorry, I know very little about unix. Could you please give me a step-by-step walkthrough of your instructions?
                        • DJAndrom3da
                          100.6k
