    No audio
    audio
    4359
    • PeterD
      PeterD last edited by
      Hi everyone,
      i bought an rasperry pi integrated in a gameboy on ebay but the sd card was corrupt so i had to reformat it.
      After a while i got the buttons to work using the gpio settings in the config file (controller part).
      But now i still don't have audio.I have tried the different settings in the audio settings but i still don't have audio coming from the headphone jacket or speaker.
      The other problem i have is that i don't have an ip adress in recalbox so i can't connect it to my network to upload roms.
      Does anyone know how to fix these problems?
      Thanks!
        Substring @PeterD last edited by
        @PeterD plug a usb keyboard on it ?
        • PeterD
          And what should i do then? What do i have to adjust in the programming?
            @PeterD log in, get the available audio devices by typing cat /proc/asound/cards and give me the output
            • PeterD
              @Substring it says KOM2835 NL9N
                @PeterD looks like the onboard audio is disabled then. Weird ...
                Which pi is inside the GB ? a pi0 ? pi2 ?
                • PeterD
                  @Substring It has a Raspberry pi 3 inside
                    @PeterD the command i gave you should list a bcm2835 which is the onboard audio. You didn't mention it, 'im surprised
                    • PeterD
                      @Substring it could be bcm2835 too because it is very hard to read the text because of the small screen. What should i do if it is that text?
                      Thanks for all your help!
                        @PeterD you should first of all know how the sound is routed inside your gb : through some pwm gpio ? a usb device ? the usual jack output ?
                        • PeterD
                          @Substring the first time i used the gameboy i had sound coming from a little speaker or from the jack output when using a headphone..
                          I had to enable the gpio in config to use the buttons on the gameboy..
                          But to the sure i should probably open up the gameboy..right?
                            @PeterD i'm afraid yes, unless you're scared to (which i'd understand). Maybe you could tell if the headphone jack was the pi one or not ?
                            • PeterD
                              @Substring I was alble to find to problem i had to set the audio to jack in the .config file.Now the sound works 🙂 The last problem i have is that when i plug an ethernet cable into the raspberry i do not get an internet connection and a weird ip adress with all kinds of weird numbers and signs appears on the raspberry. Do you know how to fix that? Thanks!
                              • PeterD
                                @Substring i get this ip adress when i plug in an ethernet cable : fe80::ba27:eb27
                                Do you know how to fix this?
                                • PeterD
                                    @PeterD this is an ipv6. It happens when dhcp failed
