    How To Regenerate A Specific ROM Folder?
    Emulator Arcade/PC/Console
    regenerate specific rom
    14513
      Substring @tdelios last edited by
      @tdelios the way the share_init/roms folder is generated was totally remade in 4.1. I may have missed a system but no : colecovision IS there. Get the files from https://github.com/recalbox/recalbox-buildroot/tree/master/board/recalbox/fsoverlay/recalbox/share_init/roms/colecovision
      tdelios 1 Reply Last reply Reply Quote 0
      • tdelios
        tdelios @Substring last edited by
        @Substring so what are the steps\commands to dump them into the 'colecovision' sub-folder assuming I have to create it under the share_init/roms folder using terminal in WinSCP?
          @tdelios So, through SSH :
          mount -o remount, rw /
          mkdir /recalbox/share_init/roms/colecovision
          cd /recalbox/share_init/roms/colecovision
          wget https://raw.githubusercontent.com/recalbox/recalbox-buildroot/master/board/recalbox/fsoverlay/recalbox/share_init/roms/colecovision/_lisezmoi.txt
          wget https://raw.githubusercontent.com/recalbox/recalbox-buildroot/master/board/recalbox/fsoverlay/recalbox/share_init/roms/colecovision/_readme.txt
          reboot
          Tadaaa should work as expected
          • tdelios
            @Substring the commands worked, but once I rebooted the Raspberry Pi, the 'colecovision' sub-folder was not automatically created in the share\roms
            I'm basically tapping out for a manual fix..
            Do you know when the 'stable' version of 4.1 may come out roughly or at least do you have a link for me to download the image file of the 'unstable' 4.1 so that I can redo a full build on that version to start.
            thanks for all your help
            tom
            paradadf Substring 2 Replies Last reply Reply Quote 0
              paradadf Staff @tdelios last edited by
              @tdelios are you sure you are on (the latest) 4.1 unstable? If so, have you try updating again?
                @tdelios we never give any ETA. And I do believe your 4.1 is totally broken
                Get the .img here : http://archive.recalbox.com/updates/v1.0/unstable/
                remember, this is unstable, expect some changes, even in an img, oe day or another. That's why i will never stress enough to put roms on a USB key. This way you are safe of experimenting on the SD without fearing anything for your roms
                tdelios 2 Replies Last reply Reply Quote 0
                • tdelios
                  @Substring thanks for the link... I've worked in software and hi-tech my whole life.. so taking your comments to hear.. lol...
                  cheers
                  tom
                  • tdelios
                    @Substring @paradadf
                    Interesting experience.. from the link you provided: http://archive.recalbox.com/updates/v1.0/unstable/
                    in which I downloaded the Raspberry Pi 3 image recalbox.img (sha1) using link: http://archive.recalbox.com/updates/v1.0/unstable/rpi3/recalbox.img.xz.sha1
                    I loaded the image on a fresh new Micro SD card and rebooted the system.
                    When I used my Windows computer to \recalbox\share\roms
                    I noticed that the 'colecovision' folder is not in there as well !!!
                    when I used WinSCP and terminal into the system, I ran the
                    ls -la /recalbox/share_init/roms command and 'colecovision' appears in there.
                    I rebooted my recalbox a couple of times to see if it would self-generate the 'colecovision' sub-folder in the \recalbox\share\roms but it didn't...
                    And this is a fresh new install using your image file on virgin Micro SD card with nothing on it.
                      @tdelios the share part is created by a script on boot if it's missing. The same goes for every folder in the share_init/roms folder. When I told you that it should be created, i tested it myself on my pi. So i'm very sceptical about what you're saying, although i'll try
                      • tdelios
                        @Substring give it a try using your Pi3 and the link I provided to you.. clean micro SD memory card. Use Win32DiskImager or whatever you use to load the image file from the link I gave you. Put it in the Pi3 and then let it go through.. Reboot once or twice if you want for good measure and then use your windows computer to \recalbox\share\roms
                        and you tell me if you see the 'colecovision' folder. It probably won't be there as I am going to do the steps one more time..
                        And then check the share_init using
                        command and 'colecovision' should appears in there but not in \recalbox\share\roms
                        • tdelios
                          @Substring
                          so I tried it again on a brand new Micro SD card on my Pi3 with the same steps downloading the 4.1 unstable img file file and loading it and rebooting.
                          Same result. The 'colecovision' sub-folder does not get created in the \recalbox\share\roms
                          but the 'colecovision' sub-folder does exist in the \recalbox\share_init\roms .
                          Not sure why it is not re-generating after reboot.
                          I even tried to install a fresh install of 4.0.1 and then perform the upgrade to 4.0.2 and then change the updates.type=unstable in the recalbox.conf file with a reboot after, but for some reason it does not detect an update to jump to 4.1 from 4.0.2
                            @tdelios said in How To Regenerate A Specific ROM Folder?:
                            This has been locked because downgrading bricks your recalbox. This happened to too many users so we took measures to prevent such a situation.
                            can you md5sum /etc/init.d/S12populateshare ? you should get e79fc4bbb19cc57d1e0d2d23097e10b9
                            And please provide me the (big) output of bash -x /etc/init.d/S12populateshare start in a pastebin/hastebin
                            • tdelios
                              @Substring
                              /recalbox/share/system$ md5sum /etc/init.d/S12populateshare
                              84ad3f127f3dd129421d87512e8ba5e0 /etc/init.d/S12populateshare
                              /recalbox/share/system$ bash -x /etc/init.d/S12populateshare start
                              • IN=/recalbox/share_init
                              • OUT=/recalbox/share
                              • for DIR in cheats system/.cache system/.config/lirc system/.emulationstation/themes system/bluetooth system/configs system/logs
                              • test '!' -e /recalbox/share/cheats
                              • test '!' -e /recalbox/share/system/.cache
                              • test '!' -e /recalbox/share/system/.config/lirc
                              • test '!' -e /recalbox/share/system/.emulationstation/themes
                              • test '!' -e /recalbox/share/system/bluetooth
                              • test '!' -e /recalbox/share/system/configs
                              • test '!' -e /recalbox/share/system/logs
                              • for FILE in music bios extractions kodi saves screenshots system/.config/lirc/lircd.conf 'system/.emulationstation/{es_input.cfg,es_settings.cfg}' 'system/{.hatari,.kodi}' 'system/configs/{fba,mupen64,retroarch,shadersets,moonlight}' system/recalbox.conf bios/mame2003
                              • test '!' -e /recalbox/share/music
                              • test '!' -e /recalbox/share/bios
                              • test '!' -e /recalbox/share/extractions
                              • test '!' -e /recalbox/share/kodi
                              • test '!' -e /recalbox/share/saves
                              • test '!' -e /recalbox/share/screenshots
                              • test '!' -e /recalbox/share/system/.config/lirc/lircd.conf
                              • test '!' -e /recalbox/share/system/.emulationstation/es_input.cfg
                              • test '!' -e /recalbox/share/system/.emulationstation/es_settings.cfg
                              • test '!' -e /recalbox/share/system/.hatari
                              • test '!' -e /recalbox/share/system/.kodi
                              • test '!' -e /recalbox/share/system/configs/fba
                              • test '!' -e /recalbox/share/system/configs/mupen64
                              • test '!' -e /recalbox/share/system/configs/retroarch
                              • test '!' -e /recalbox/share/system/configs/shadersets
                              • test '!' -e /recalbox/share/system/configs/moonlight
                              • test '!' -e /recalbox/share/system/recalbox.conf
                              • test '!' -e /recalbox/share/bios/mame2003
                              • for DIR in roms roms/mame/mame2003
                              • test '!' -e /recalbox/share/roms
                              • test '!' -e /recalbox/share/roms/mame/mame2003
                              • test -e /recalbox/share/system/ssh
                              • ls /recalbox/share/system/bluetooth
                              • read X
                              • mkdir -p /recalbox/share/system/udev/rules.d
                              • rm -rf /run/udev/rules.d
                              • ln -s /recalbox/share/system/udev/rules.d/ /run/udev/
                              • cp /recalbox/recalbox.changelog /recalbox/share/system/recalbox.changelog.done
                                @tdelios how the heck have ypu mounted the share folder ?
                                • tdelios
                                  @Substring
                                  not sure what you mean.. I just did the following as per my previous post:
                                  I unzipped the IMG file and loaded the image on a fresh new Micro SD card using Win32DiskImager and rebooted the system.
                                  100.2k
