    Recalbox manager, i cant acess
    recalbox manager cant acess
    3151
    • Pablo Macaluso
      Pablo Macaluso last edited by
      Im trying to connect to my recalbox manager. with my IP : and not works.
      • No se puede acceder a este sitio web
      La página 192.168.0.13 ha rechazado la conexión.
      Prueba a:
      Comprobar la conexión
      Comprobar el proxy y el cortafuegos
      ERR_CONNECTION_REFUSED
      Any help?
      Pepe Substring 2 Replies Last reply Reply Quote -1
      • Pepe
        Pepe @Pablo Macaluso last edited by Pepe
        @Pablo-Macaluso Dando por hecho que tu Recalbox esté correctamente conectado a la red, revisa que el web manager esté activado en recalbox.conf, si está a 0 está desactivado y deberás cambiarlo a 1 y reiniciar.
        /recalbox/share/system/recalbox.conf
        system.manager.enabled=1
        Pablo Macaluso 1 Reply Last reply Reply Quote 0
        • Pablo Macaluso
          Pablo Macaluso @Pepe last edited by
          @Pepe Si lo raro es que estaba activado. Pero me dejaba entrar, Ya formatié la SD voy a probar instalar de 0
          Pepe 1 Reply Last reply Reply Quote -1
          • Pepe
            @Pablo-Macaluso Que paciencia la tuya
              Substring @Pablo Macaluso last edited by
              @Pablo-Macaluso which recalbox version are you running ?
              • Pablo Macaluso
                Pablo Macaluso @Substring last edited by
                @Substring Im using the lastest unstable.
                Installed with NOOBS with LibreElec
                Substring 1 Reply Last reply Reply Quote -1
                  @Pablo-Macaluso So you're running 4.1 unstable (with dreamcast and PSP, just to make sure) and the manager doesn't run ? This happened a while ago, but has been fixed for some time already.
                  Can you run these commands :
                  /etc/init.d/S94manager stop
                  cd /usr/recalbox-manager2/ && NODE_ENV=production PORT=80 node dist/server.js
                  Then try to connect. Then give me the output. Make sure you have system.manager.version=2 in recalbox.conf and report 🙂
